Teeth Sharpening
tcalvin48
B2650HSD, LA534 FEL, BH77 16" bucket,thumb, WG24, BB2560, WC68, RCR1860
Aug 22, 2019
Dresden, Maine
Has anyone had their stump grinder teeth sharpen? There seems to be a question of sharpening vs recapping.
Any thoughts?
Tom Stoltz
in Maine
Vlach7
L47 305DT JD500C
Dec 16, 2021
351
257
Frazier Park Ca
Not sure if that is hardened metal, which it probably is, the only way you would be able to sharpen is with a cutting torch, and then you would lose your metal temper. I attempted to sharpen a trencher teeth and that just destroyed the grinding blades, hardened metal is impressive.
4,668
Any thoughts?
Tom Stoltz
in Maine
I am sure they can be re-sharpened with an appropriate grinder but it may be easier and more cost/time effective to simply replace them.
6,600
Matters on the type of teeth, there are quite a few.
Also some are carbide tipped, if there is enough of the carbide left a good saw shop or machine shop can sharpen them.
In some cases it's much cheaper to just replace them than it is to have them sharpened.
lynnmor
B2601-1
May 3, 2021
1,452
1,172
Red Lion
I had some stumps ground and the guy asked if the teeth could be sharpened in my tool & die shop. They were carbide tipped and were worn to the point that sharpening would be impossible to get them right. I told him to just buy new rather than have low performance resharpened teeth.
tcalvin48
Aug 22, 2019
Dresden, Maine
Not really, even re-tipping is half the price of a new tooth.
This place seems to have a good price. All my teeth are still like new. So I have never tried this place but it might be worth a shot...
Jeff's is one of the places I'm thinking about for re-sharpening. My concern is from a conversation with Scott at Wit-son/Gabdon (who makes teeth). He said the heat of re-sharpening would destroy the bond the carbide tooth has with the steel part of the tooth, that is, better to re-tip than re-sharpen. But re-tipping is about twice the price of sharpening.
Tom Stoltz
in Maine
4,668
Tom Stoltz
in Maine
I find that "heat will destroy the bond" idea hard to swallow. Regrinding bonded carbide tipped cutting tools is standard practice in the metal cutting world. There are plenty of ways to control the heat if need be. I would have a few of your teeth sharpened and test that theory out before accepting it at face value.
tcalvin48
Aug 22, 2019
Dresden, Maine
Thanks Dan, that's sorta what I thought. I'll call Jeff's sometime this week and talk to him.
Tom Stoltz
in Maine
Daferris
LX2610
Nov 23, 2021
483
404
Mid-Michigan
Also all the carbide tools I have ever used the carbide is brazed to the steel. No way grinding is going to get the steel hot enough to melt the brazed tip.
4,668
Exactly. The teeth on my Woodland Mills grinder appear to have conventional brazed carbide tips.
