Is there a trick to get the roll pins out? Wedged in there and it won’t allow me to see if the linkage came apart in the housing without getting that pin out, split the tractor and can’t see muchHey folks back for knowledge. I got my l35 split again and am lost what it am looking for. Once again I have not done any transmission work and it work before disassembly the 1st time . Splitting the engine I can’t see much except for the fork and release bearing? The fork was not lined up right. Would this make the tractor not shift? With it being stuck in reverse before is there a way to get it neutral or is that important before I start the install again.
