Who's Using a Trickle Charger / Battery Tender?
lmichael
Kubota G2160
Apr 23, 2021
742
352
Rockford IL area
YOU have to select the type and mode of operation. I can't see any way for someone to have their device KNOW what battery (manufacturer and model ) it is connected to until 'they' start putting 'chips' in them.
Easiest way would be to embed RFID tags with make/model info as well as date of manufacture.
great, I've just given someone a multimillion dollar - never work again idea.......
So here is something then. The Battery Tender has a selection but can and does automatically select the proper battery. Even my Hazard Fraught 4 Amp Fully Automatic Microprocessor Controlled Battery Charger/Maintainer (harborfreight.com) selects the proper battery type. Not knocking the NOCO. Looks like good stuff, but given how many power surges we have that knocks our power out for a few seconds, I would constantly be running back to the garage, and having to "reset" the charger.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,008
1,382
Pittsburgh
For lead/acid I don't think the type really matters apart from the saturation voltage.
One of my Optimates has a selector to switch between 14.2 volts and 14.8 for AMG applications. Beyond that, for 12 volt batteries the cpu controlled maintainers deduce the saturation point and then float/analyze.
lmichael
Kubota G2160
Apr 23, 2021
742
352
Rockford IL area
IDK how it knows but I have tested this with the Hazard Fraught charger. I have one piece of equipment with AGM and of course the tractor with standard lead acid. And it picks it up immediately. Don't ask me how but it does. I have not tried it with the Battery Tender one, but it works great with the HF one
5,178
yeah... $39 to $78 CDN depending on the website you buy from..and of course shipping, handling and 13% for the guvs....
13% ONLY in Canada, and 15% in some provinces!
"Free medical care" ...they say!
5,178
I had never heard of NOCO. Looked it up. So I noticed a "mode" button. Do they make you select a mode or are they smart enough to sense the type of battery and set accordingly (as is the Battery Tender and some others). Having to constantly "check" it would be a royal PIA. Every time power blinked or surged what have you then you have to run out to the shed and reset the device.
Yup,.... with the NOCO mode selector, you must "run out to the shed" to select from 6V to 12V to 24V etc.
You have a Battery Tender that will automatically switch itself for charging various voltage batteries without a "run out to the shed"?
I gotta get me one of those!
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,128
3,388
Well....my first Battery Tender Jr died yesterday. Blinky red/ green light no matter what I put it on. It was a good run for 21 years. Kept the truck topped off all last winter in single digits on top of thousands of hours on a motorcycle, mower, scooter, etc.
Hopefully the newer ones last as long. I think my next oldest is 10 or 11.
5,178
For replacement, the NOCO Genius (Amazon $29.47) beats the price pants off the Battery Tender, or the BT Jr.
lmichael
Kubota G2160
Apr 23, 2021
742
352
Rockford IL area
Well Costco has a good price on them. Bottom line I don't want to have to run out to the shed every time my power "hiccups".
5,178
I have heard people sing their praises but for the price I get the Deltran products it's cheaper to stick with them.
I respectfully disagree!
Deltran was early to the party, and earned a lot of respect.
Now they are price abusing that loyalty.
Equal, or better stuff out there now,....and for less money!
I currently own 10 Deltran products, but am not a creature of habit!
5,178
Don't know where you came up with the "run out to shed" story, but NOCO customer service states that your assumption(?) is INCORRECT!
"A NOCO Genius 1 amp. charger reset is NOT required after a power interruption"!
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,128
3,388
Nor am I, but the NOCO is more expensive for me AND then to buy a $20 adapter for their silly connector. Is NOCO better? Maybe. Maybe not. But when I get 7 years out of a motorcycle battery and 9 in a car..... I think I'll stick with the Deltran.
5,764
'hiccups' can either reset the device or damage it or destroy it
if it properly resets then it'll work as before,well it should...
if it damages it, it could 'alter' how it hows,usually not good..
if it destroys it, it's more Ewaste to deal with ,as in... 'no user serviceable parts inside'
a lot of PIR motion outdoor lights have the ability to stay on , if you flip the power switch, off-on ,at a certain rate of speed. It's common to have 'hiccups' (wires blowing in the wind,bzz,) that just happen to mimic that.... then the dang light is ON until you kill power to it.
5,178
And....the point here is...?
Maintenance chargers should not be used because they might fail in a power outage?
I have been using such chargers for 20+ years, and have had only a few failures.
5,764
The point is that a properly designed and built device should work fine after power 'hiccups', power failures and nearby lightning strikes.
None of my remote energy control systems ever failed or 'died' do to those conditions and some had 15 miles of wire attached to them.
5,178
I am confused!
A $20 adapter?
A "silly connector" .....that being a standard two prong 110V plug?
$29.47 for the NOCO Genius 1 on Amazon, is more expensive than the Battery Tender price?
Where are you finding Battery Tender, or even BT Jr., pricing, below $29.47?
The technology is essentially the same in these little maintenance chargers.
I do not quite understand why would anyone want to pay double, just for the "Battery Tender" name?
lmichael
Kubota G2160
Apr 23, 2021
742
352
Rockford IL area
This came from You of all people
So now you're tellin me it's NOT that case? Which is it?
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,128
3,388
I am confused!
A $20 adapter?
Im not talking about the 120v end. The battery end. All my batteries are hardwired with a SAE 2 prong plug. The NOCO does not use that. They have their special widget.
Deltran is a sponsor. I run their Li batteries in my race bikes. I get em for a little less than most folks.
lynnmor
B2601-1
May 3, 2021
1,627
1,409
Red Lion
Since country of origin was mentioned eariler in this thread, I checked my two 1.25 amp Battery Tenders. The rather old one was made in China, the rather new one was made in Vietnam. I rotate the two between the ten seasonal batteries keeping them connected about three days each time.
