Hello all my old trusty L35 finally has asked for help. I lent it to a neighbor and they were working it hard and it started to move slowly no matter what gear and then stopped moving at all. Nothing at all no matter the gear or forward/reverse. The clutch pedal feels solid in and out but has a different creaking that is very slight that wasn’t there before. I assume the clutch is shot, probably throw out bearing and pressure plate also. But I have also read about some issues with hydraulic pressure needed at the clutch and also about shuttle issues with a c-clip and a weak case?
Any help in diagnosing anything before I make the leap and split this machine would be helpful. I thought I saw there was a way to check pressures somehow with a grease fitting type setup?
Also while in there if/when I do split the case, what all should I replace or check?
Thanks in advance for anything you can share!
