Can anyone give me a part number (s) for these guards? I can't find a listing on the Kubota parts website. Or a heavier aftermarket manufacturer would be even better. Thank you for your help.
I don't see the guards for the BT1000 on the L47. They are shown on the BT1200 for the M59. You could probably adapt those or fabricate some from scratch.Can anyone give me a part number (s) for these guards? I can't find a listing on the Kubota parts website. Or a heavier aftermarket manufacturer would be even better. Thank you for your help.
I couldn't find it on Messicks because I never removed my search for L47 parts. After I removed that search I found the parts list. Thank you.Did you try Messicks? Use you BH model number
Kubota Parts | Buy Online & Save
Messick's has the industry's largest ready-to-ship, in-stock inventory of OEM Kubota parts and accessories for sale online. We ship nationwide, often same day.www.messicks.com
The guards are listed under the BT1000B backhoe. Part numbers 7K529-53212 and 7K529-53222 The BT1000 is for the L39 according to Messicks.I don't see the guards for the BT1000 on the L47. They are shown on the BT1200 for the M59. You could probably adapt those or fabricate some from scratch.
I think I looked at the BT1000A for the L45, didn't see the -B. The guards must be an addition to the newer models.The guards are listed under the BT1000B backhoe. Part numbers 7K529-53212 and 7K529-53222 The BT1000 is for the L39 according to Messicks.
You are correct, it is. I guess people got tired of bending hydraulic lines so Kubota fashioned some guards.I think I looked at the BT1000A for the L45, didn't see the -B. The guards must be an addition to the newer models.
I wonder if those cylinder guards would fit my L48 TLB?You are correct, it is. I guess people got tired of bending hydraulic lines so Kubota fashioned some guards.
I'm not sure. If I actually HAD my L47 I'd measure the mounting points, but alas, it's still 3 weeks out.I wonder if those cylinder guards would fit my L48 TLB?
Make the guard fit! you might need to drill new holesI wonder if those cylinder guards would fit my L48 TLB?
The downside of my trying to make the guards fit is that I have absolutely zero rocks to contend with.Make the guard fit! you might need to drill new holes
Do what works for you!The downside of my trying to make the guards fit is that I have absolutely zero rocks to contend with.
The largest "rock" that I have on my property would be slightly larger than a pea.
Very light sandy loam, and pure sand below, so I really do not have much of an actual need for "shin" guards.
I just bought stabilizer street pads, and I really don't need those either, because I never use my hoe on asphalt.
