Water Separator
lmichael
Kubota G2160
Apr 23, 2021
851
440
Rockford IL area
So somewhat new to diesel. I see some threads here mentioning water separators. I see only fuel filters on my G2160. So it leaves me somewhat curious. Should I install a water separator on my machine? If so any recommendation on what to get, where to install?
I know enough to know water should not be present, and am very careful with my fuel. So an inquiring mind wants to know.
4,220
Doesn’t your machines’ filter already have a water-separating-filter-bowl with a water-detector-ring ?
kubotafreak
Sep 20, 2018
1,049
402
Arkansas, US
There are two of those filters, one by the lift handle, and one by the engine. (imperative they are oriented right) They are water separating in nature. The water remains in the body unless the filter gets too full of water. The fuel passes easier through the element. You just replace them to get rid of the moisture/water. A separator unit like the tractors would be an upgrade.
You can see the water collected easy on the engine mounted filter. The bottom will not be as dark indicating water in the cannister. Granted I use red diesel, it should still be apparent through the white housing.
11,143
The inline filters do separate water, just a very small amount, like Kubotafreak just said.
You could add one of these if you can find room for it, that's the issue with most of those models.
lmichael
Kubota G2160
Apr 23, 2021
851
440
Rockford IL area
Pretty cool. I will keep those in mind but I didn't know the inline filters did that as well. I plan on replacing them again this spring after a trip to the dealer to buy some.
Cheryl
M5030
Aug 14, 2021
26
louie1456BP
Are there any water separators with a larger, clear bowl, preferably without a filter? My M5030 has a filter with a drain on it, but it's not see-through. This is my second year with this tractor and the second winter I've had a bunch of water in the fuel, in spite of the tank being full.
I would like to be able to inspect my fuel before every start. The little clear tubes used in general aviation to drain fuel from the low point of the tank before a flight, would be acceptable.
kubotafreak
Sep 20, 2018
1,049
402
Arkansas, US
Seems excessive, even for a metal tank to get that much water if you are keeping the tank full. I would suspect the fuel cap and diaphragm. Is the filter drain 1/4”? If so you can easily get a thumb screw tank drain fitting.
Racor makes screw on filters with clear bowls for the lower half. You would need to find the suitable micron rating. The filter flanges are pretty universal.
Cheryl
M5030
Aug 14, 2021
26
louie1456BP
Diaphragm? I am completely ignorant about any diaphragms relating to the fuel system.
kubotafreak
Sep 20, 2018
1,049
402
Arkansas, US
Most fuel caps have a vent built in. It is some form of rubber/foam.
