Battery and freezing temps
Whiskey Mike
B2601 BX5455HD, RCK60-32,
Feb 16, 2022
42
15
Brewer, Maine
Is there a temperature at which one should consider removing the battery to protect it? My tractor is stored outside and we're expecting about -20°F in a few days.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,001
1,363
Pittsburgh
If it's fully charged then it won't freeze. The lower the state of charge, the higher the freezing point of the electrolyte goes.
Reactions: 7 users
5,175
If you can reach your tractor with a 110v extension cord, just put a battery maintainer on your battery TODAY!
It will keep your battery in good condition for EVERY day!
Reactions: 6 users
RBsingl
Jul 1, 2022
485
565
Central IL
My Kubota F2690, Deere 955, and Corvette Z06 all have battery maintainers on them during the winter. A fully charged battery will lose a lot of power in very cold weather but it won't freeze at temperatures found in any inhabited area of the world.
Rodger
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
Trivia .
Fully charged battery will freeze around -80 F. -62C
Dead battery will freeze at 20 F -6C
5,725
ALL batteries are like humans, even if 'fully charged' cannot deliver 'full performance' when cold.
Just because it's 'fully charge' doesn't mean it WILL start your tractor.
BruceP
G5200H
Aug 7, 2016
852
370
Richmond, Vermont, USA
Although what you say is correct... the OP seems to be asking about battery STORAGE at -20F.... not starting an engine. :)
Starting a diesel engine at -20F is a totally different discussion.... not to mention hydraulic fluids and HST motors.
RBsingl
Jul 1, 2022
485
565
Central IL
Excellent point Bruce and this is why the 3.3L Mitsubishi turbo diesel that powers my standby generator has thermostatically controlled oil pan and coolant heaters. Being the "belt and suspenders" type when it comes to stuff like this, its heavy duty starting battery stays on a maintainer AND I have a big JNC jump pack in the house just in case.
I don't mind getting cold outside but I like having lights and heat inside :)
Rodger
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
790
687
E.
agree.....
I live in a very cold area and I have yet to ever freeze a battery but then again I test my batteries and if they are in a state of failure I replace.
good batteries good to -80f ... very bad batteries can freeze in the 20's.
I am more concerned with loss of power on my batteries when very cold versus freezing. At -20f your going to have about 25% of original battery power! but if just in storage doesn't really matter.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,120
3,381
Depends on how long you'll be storing it. If I'm not using something for a couple months (RV, mower, etc) then I pull em and put them on a shelf with a tender. If you'll be using it occasionally that would be a PITA to do.
If you can put a tender on it then just be done. They only pull a couple amps at the most. So even a long extension cord is fine.
3,512
Trivia .
THANK YOU for actually ANSWERING the OP’s question (instead of offering all kinds of errata that my be completely unhelpful here on the last-moment during a rapidly-developing freeze.
Biker..I’ve noticed that you consistently remain in the background and silent….until it’s time to give good advice …(or funny sarcasm)…. and then you step-up and hit the nail on the head!
I enjoy your posts (and your humor.) :ROFLMAO:
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
Thank you !
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,577
2,035
Western MT
I haven't had a battery freeze yet. My outbuildings are unheated. My RV and Truck Camper batteries are exposed to the cold. Some of my vehicles also sit outside.
I'm not saying it can't happen, but it's unlikely. Fwiw, we've had -30+ F this year.
3,716
My boat is stored in an unheated metal barn and has 3 AGM trolling batteries and an AGM starting battery.
I would rather wrestle a giant alligator then to try and remove them so I just use a battery tender and have never had a problem. I wont pull them out until it's time to replace them.
Temps in that area regularly go sub zero for extended periods of time. (see avatar)
Whiskey Mike
Feb 16, 2022
42
15
Brewer, Maine
agree.....
