NO problem, if you don't find what your looking for just ask.You sir are a true gentleman…thanks!
I have this on my lite duty bucket and it does well for light digging, grading and spreading.BXpanded Piranha Toothbar You could add one of these to your standard bucket, they work well.
So I was after a Land Pride CB 2574 combo bucket for a used L47 I plan to pick up next week. I have loads of excavating and some brush pick up. My local shop advised the following
" The bucket you are referencing is engineered to fit a skid steer. While it will attach to your loader, it's substantially heavier than what Kubota recommends for the L47."
Does anyone have any experience with this and should I avoid a Combo Bucket?
If you were closer I'd buy it. I want something for grading and landscape clean up.My 4 in 1 weighs 700lbs, is 70"width and has teeth. It is rated as medium duty and is for a large tractor or medium size skid steer. I have loaded and weighted rear tires (about 1300lbs total) I then add a 1k ballast box. My tractor does fine pushing and filling bucket. Dry material it lifts everything, wet it struggles with a full load. Lots of flexing and bouncing.
I purchased 4 in 1 thinking it could dig well and replace a grapple (dealer agreed). I was wrong, a grapple can do much better than a 4 in 1 in brush and debris. If dirt work is the primary job a 4 in 1 will work but a dirt bucket with teeth might work better.
For You, with an M59 it might be OK.If you were closer I'd buy it. I want something for grading and landscape clean up.
