Welcome home! Are you trying to manipulate something using the backhoe valve, or hook up remote connections with the hoe off, or hook up something like a thumb on the hoe?New to the game, and looking for a suggestion to use the Backhoe hydraulics as a rear control? Is there anything out there that does that conversion?
L4701
Looking to manipulate things like a hydraulic top link for blades or a side shift on a mower.Welcome home! Are you trying to manipulate something using the backhoe valve, or hook up remote connections with the hoe off, or hook up something like a thumb on the hoe?
The best way to do that is to add an auxiliary valve and some remote outlets. The valve is easily added to the backhoe supply and return circuit.Looking to manipulate things like a hydraulic top link for blades or a side shift on a mower.
It will work but mighty expensive. A simple two spool valve is $150 - you supply hoses and outlets.Rear Hydraulic Valve Kit for Kubota MX & L Series Tractors (Two Spool, Three Spool, Four Spool)
Electric Rear Remote Valve Kit for Kubota MX & L Series Tractors (Two Spool, Three Spool, Four Spool) Free Shippingsummit-hydraulics.com
Would something like this work to splice into the lines?
How would that be controlled?It will work but mighty expensive. A simple two spool valve is $150 - you supply hoses and outlets.
At the risk of being accused of shameless self promotion:How would that be controlled?
Is there a way to install the 2 spool valve and connect the supply and return hoses from the valve to the backhoe connection?At the risk of being accused of shameless self promotion:
EZ-PZ Kubota Tractor Remotes
An affordable easy to install auxiliary valve kit customized to fit L01 and L02 series tractors. No hydraulic expertise required and kit can be installed in about 30 minutes.windyridgefarm.us
Its a simple and affordable way too add a couple rear remotes. The only downside is the hoses for the remotes do have to be run under the tractor and all the way to the rear.
At the risk of being accused of self promotion:How would that be controlled?
In effect that is what that does. The AUX valve is simply installed in the supply line going from the loader valve to the backhoe. Connection point is at the loader rather than the rear of the tractor.Is there a way to install the 2 spool valve and connect the supply and return hoses from the valve to the backhoe connection?
I apologize if this is cumbersome for you, I don't have a lot of experience with this, and I'm trying to process haha. Hypothetically speaking, if I could mount the valve to the rops, could I connect the supply and return via the backhoe connections and have the rear implement connect to hoses coming off the valve? Almost like a plug-and-play setup?At the risk of being accused of self promotion:
You could do the same thing at the rear but you need to come up with a way to mount the valve on the tractor. The advantage would be much shorter hose runs for the remotes or potentially putting them on the valve itself. That gets a little tricky because of the narrow port spacing on the valve.
its no botherv- am doing this right now.I apologize if this is cumbersome for you, I don't have a lot of experience with this, and I'm trying to process haha. Hypothetically speaking, if I could mount the valve to the rops, could I connect the supply and return via the backhoe connections and have the rear implement connect to hoses coming off the valve? Almost like a plug-and-play setup?
I have a 3rd function on the front, does that change anything with the kit in the link you sent?its no botherv- am doing this right now.
There is no advantage to using the backhoe outlets - it just adds quick connects you do not need:
THats exactly how the $2000 factory remotes would be plumbed. The valve is alwzys hot abd your backhoe operation does not change.
- Disconnect the hose going to the backhoe supply quick coupler and connect it to inlet on the AUX valve.
- Connect the power beyond outlet on the AUX valve to supply quic connect for the backhoe.
- Connect the tank return on the AUX valve to the tank port on the tractor hydraulic outlet block.
Probably. I dont know what third function you have but it probsbly interferes with the mounting location of the EZ-PZ kit. I am working on a ROPS version. of the EZ-PZ kit.I have a 3rd function on the front, does that change anything with the kit in the link you sent?
Depending on how your third function is done, you might could add a section or replace the valve with a 2 or 3 spool valve. Or, if you just want one rear remote, run hoses to the back and use your third function.I have a 3rd function on the front, does that change anything with the kit in the link you sent?
Unfortunately the third functions are almost universally manifold mounted D03 solenoid valves - you dont just add sections.Depending on how your third function is done, you might could add a section or replace the valve with a 2 or 3 spool valve. Or, if you just want one rear remote, run hoses to the back and use your third function.
I've entertained doing something similar to what you're thinking about. If you're thinking about plugging it into the backhoe hoses when the hoe is off, you wouldn't be able to use it for a hydraulic thumb. You might as well mount and plumb it up permanently.
Post a picture of your third function. I'm thinking your easiest solution may be to put in one valve with more sections.
The kit is built and tested on L01 tractors with factory loader but it can be tweaked to work on most L series tractors with a loader. Its generally just a matter of adjusting the length and/or end fittings of the hoses supplied with the kit. Hoses are all custom made to fit the tractor it is going on.So is this kit for installing remote's for the loader or rear remotes ? Will this kit work on a L3301 HST . Is there a set on istructions you can share ?
thanks
animals45
