The Titan Lug R1 tire size is 11-2-24. The Kubota load rating is @ 2500 lbs. The Titan psi site shows a choice of 18, 26,or 36psi. My rear tires are additionally weighted with water. Can anyone please recommend the correct pressure? Thank you !
Windshield washer fluid (rated for apropriate below freezing temp) is the cheapest by far, and you can do it yourself, with an adapter from TSC.Fifteen pounds is about the normal rear tire pressure for most tractors. I believe most people fill their tires with beet juice or some derivative to be environmentally responsible and keep their tires from freezing. I think some use automotive windshield washer solution. Ask a couple of dealers, I just run air.
Is that tire a tubeless type? I am currently looking at replacing the rear tires on my tractor?The Titan Lug R1 tire size is 11-2-24. The Kubota load rating is @ 2500 lbs. The Titan psi site shows a choice of 18, 26,or 36psi. My rear tires are additionally weighted with water. Can anyone please recommend the correct pressure? Thank you !
Hey there!The Titan Lug R1 tire size is 11-2-24. The Kubota load rating is @ 2500 lbs. The Titan psi site shows a choice of 18, 26,or 36psi. My rear tires are additionally weighted with water. Can anyone please recommend the correct pressure? Thank you !
