Using vacuum to not lose hydrostatic fluid?
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,938
2,335
Western MT
If you've used a vacuum to prevent losing hydrostatic fluid on a filter change, how did you do it? Is it as simple as putting the vacuum hose over the fill opening?
jyoutz
Jan 14, 2019
3,622
2,716
Edgewood, New Mexico
That’s how it was described to me by the dealer. I didn’t do it because I didn’t have an extra hand when I changed my filters. I lost about 1/2 quart and made a small mess.
10,994
Yep most have raved about it, I'm a spin and replace quick kind of guy!
OntheRidge
Nov 1, 2020
494
585
I made this adapter, duct taped shop vac hose to it. Threads right in, no fluid lost.
3,057
I think the vacuum idea is a very crafty one - pure genius.
But For the cost of the PVC and fittings and glue etc.......... the loss of 4-6 oz of fluid will be cheaper!
Have you seen the @#$%@#$$%@# cost of PVC?
Eggs are cheaper per foot!
jyoutz
Jan 14, 2019
3,622
2,716
But For the cost of the PVC and fittings and glue etc.......... the lost of 4-6 oz of fluid will be cheaper!
I’d prefer to avoid the mess.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
573
249
CNY
The concept has been around a long while. I have one of these but you can find cheaper generic versions if you look.
Connect it to any reservoir and connect an air hose to it and the venturi inside creates the vacuum. It can even collapse a weak reservoir. You can change hyd. hoses or components without losing more than a drop or two. It also works on cooling systems. You can open the system to change a hoses or install a block heater with loosing much if any coolant.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
530
Benton City, WA
Some of us have extra irrigation fittings around. The thread on my L2501 is one inch NPT. Since leaking isn't an issue I didn't bother gluing things together, the vacuum holds things. If worried one may use duct tape.
wsurff
L6060, Backhoe, Front Snow Blower, Grapple, Chipper, Box Blade
Oct 8, 2021
64
45
NJ
Yup, I have a small sized shop-vac (I think from Lowes). The fittings are smaller than full-size shop vacs. I just place the end right on the fill opening, turn on the vac, does the job.
trueg50
60
78
Vermont
Vacuum trick worked beautifully. It's also an easy/clean job and I managed to get my wife to help hold it while I changed the filters.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,442
637
Richmond, Virginia
I parked my tractor on a steep incline. Back wheels on the flat, fronts on the hill. When I took off the old filter, no fluid came out.
beckmurph
Kubota LX2610TLB/Woods finish mower/woods rotary cutter/
Aug 23, 2012
330
315
catlettsburg, ky
I used a shop vac hose adapter/reducer from Lowes.
Put the end in the filler opening, turned the vacuum on and changed both filters.
I lost very little hydraulic fluid.
John T
2017 BX23S
May 5, 2017
1,290
813
under a rock
I always remember to use the vacuum trick....
Right AFTER I change the filter... :rolleyes:
GibbyESS9
2020 Bx23s,BX2672 plow, Titan Forks, Land Pride 48” BB, FEL, Bestco Flail mower
Sep 30, 2020
107
137
Blue Point NY / Newfoundland PA
I used my small rigid shop vac when I did mine, and was surprised that I actually sucked some Hyd fluid into the vacuum. Not much but had to clean the vacuum. I didnt have an extra hand, so I probably taped it too tight to the fill spout.
old and tired
1,919
1,297
For sure if you have the vacuum set to blow air out instead of sucking air, you will loss a lot of oil and make a mess of the shop floor. The shop vac also sounds the same, blow or suck... 🤬👺
