B7100 issues
Bobsbait
B7100
Jul 20, 2022
19
B7100 got one had short y guys helprd me now got fuel leak have replaced o rings x2 still leaks my dealer says need seroal number have took everthing
Does anybody know where i can get those cooper washers and o ringd
11,292
First your going to have to be a little more specific as to what is leaking and where, there are several copper sealing washers and O-rings throughout that tractor.
Why is it an issue to give the dealer the serial number?
It's stamped into the side of the clutch housing.
It will either be B7001-XXXX or B7100-XXXXX or some variant of those 2.
He needs the serial number because there is several variants to the B7100's.
And for us to give you a proper answer we would need that serial number too.
Bobsbait
B7100
Jul 20, 2022
19
I took those nimbers the leak is i belive coming from pump where yhe lines connect do not think iz iz oring but would chsnge it all out
11,292
Get me your serial number and I'll tell you what the part numbers are needed. ;)
11,292
Top of pump suction side, O-rings (2 of them) 04811-00220
Bottom pressure side Copper rings (2 of them) two possibilities:
Early models 04714-00300
Late models 67111-37180
11,292
Looked on left side b7100ehh11989 then engine model dt750ah then another b7100hste any of these right thanks
Yep that did it, its a new type B7100HSTE
This is what you need:
Bottom pressure side Copper rings (2 of them) 67111-37180
Bobsbait
B7100
Jul 20, 2022
19
Kinda confused theres 3 lines so 2 orings one bottom of line one at top for injector one one copper washer so think need 6 orongs 3 cooper washers thanks am old work on my cars trucks but not disel been learning experirnce
11,292
Oh sorry, you said pump leaking, I was thinking hydraulic
I didn't get that you meant Injection pump.
#70 (3) 15331-96760
#50 (3) 15331-51240
#240 (1) 14111-53380
#180 (2) 15331-96650
Bobsbait
B7100
Jul 20, 2022
19
Would that be for each line still vpnfused but thanks for part numbers.think middle line is leaking but want to do them all
11,292
These set of (3) is one for each delivery valve that comes out the top
#70 (3) 15331-96760
#50 (3) 15331-51240
These are for the feed line from the lift pump
Bobsbait
B7100
Jul 20, 2022
19
Could you give me part number for pto seal going to get my parts this week thanks
3,163
You can get part numbers from Kubota USA dot com and the illustrated parts list
