1998 B7300 Axle pivot leak...
7,158
Easy repair, just a couple of O-rings and maybe bushings if it's warn too much.
I'll post pictures in a bit.
7,158
You more than likely just need new O-rings.
Jack it up off the front of frame, and block it up, remove the bolts and drop the axle.
RTMach1
B2650 ROPS,LA534 Loader, 60" MMM, B2019 front hyd blade, LandPride BB1254 box
Dec 4, 2012
Holly, MI
I had the same issue on my B2400 and 1st I tried replacing the pivot ends front and rear (with new O-rings) lasted a few months before leaking again. If you have more than a small amount of wear on the bearing surfaces on the axle housing itself it will leak again. Fast forward to last fall: I ordered the complete front axle kit which includes the axle housing, front and rear pivot castings and seals etc. (mine had Bi-speed steering so a bit different and more work). The new axle and bearings are redesigned and completely different (better) from what you have now. This requires complete tear down of the axle and differential, I recommend having a shop manual for guidance.
proyer
B7300 HST
Jan 17, 2023
I have leaks(s) and have order new O-rings. Do I have to release the drrive shaft to replace the O-rings? A little more guidance would be greatly appreciated.
7,158
The drive shaft and cover will slide off when you pull the axle out.
proyer
B7300 HST
Jan 17, 2023
7,158
Nope no need to remove the pin, the pin on the coupling is between both shafts and just keeps it from sliding back.
