2004 B2710 HST doesn't want to move after warm
Structuralguy
Kubota B2710 HST
Jan 14, 2023
North Carolina
Hello All,
My first post on my first tractor so your patience is greatly appreciated as I'm sure I'll leave out something. I bought a 2004 B2710 HST with a front end loader and 1100 hours in Oct 2022. Just wanted the tractor to move dirt and mulch around in the yard on weekends. I used it several times and noticed that driving power seemed to diminish as the tractor got warmed up. I worked around this for a while and just used the tractor 30 minutes at a time. Last week I decided to go ahead and do a full service. I changed oil and hydraulic fluid, fuel filter, both hydraulic filters and cleaned the hydraulic screens located on the "rear diff". I still have the same issue. It looks like this question has been posed a few times, but I've not been able to locate a solution. Other threads that I've found similar;
Other symptoms that may help:
  • My loader hydraulics are really strong and easily lift the front of the tractor or a bucket of dirt while the tractor is hot or cold.
  • I can cold start the tractor and leave it idle for 15-20 minutes, come back and it does not want to pull out of its tracks in high gear.
  • I can cold start the tractor and take off in high gear with minimal HST whining while the tractor is cold.
  • This issue does affect high, medium and low gears. If I use the tractor long enough, eventually it doesn't want to move in low.
I would appreciate any advice you guys could throw my way.
5,257
1,047
Please post exactly what brand and type of fluid you used.
Re loader: does your tractor have a separate hydraulic pump driven on the end of the engine crankshaft?
When using the bush hog, does the pto shaft ever stop turning when the pto is engaged?
Structuralguy
Kubota B2710 HST
Jan 14, 2023
North Carolina
Hi Dave,
I used Traveller Premium Universal Tractor Fluid Trans/Hydraulic from Tractor Supply.
I'm not sure about the separate pump at the end of the crankshaft. I don't see anything obvious that looks like a pump and the only hydraulic lines coming from the trans go to the valve on the side that also works by loader. I'm in very unfamiliar territory here so I've attached a few pictures of the underneath to be sure.
The pto does not stop turning while the pto is engaged.
3,257
The B2710 is identical to my B 2910 except for engine HP from what I understand. There is no separate hydraulic pump for the loader.
Using anything other than Kubota fluids is not a good idea. I don’t know if they could cause the problem, and apparently are not the cause since you had the problem before you change the fluids. It’s always possible that the previous owner also used non-Kabota fluids and ended up damaging the seals or something in the HST side.
So the only help I can give us to say that there is no independent pump for the loader… I’m sure of that.
9,366
Number one cause for issues like this is a failing clutch disk or pressure plate.
To test this, you need to put a PTO powered implement on the tractor.
Run the tractor to the point where it will not move, have the PTO engaged and try and move it, does the PTO slow down or stop turning, It will free coast so you need to load it a little, like a mower in grass.
As far a fluid goes, you need to change the fluids and filters and use UDT or better yet SUDT2
5,257
1,047
Hi Dave,
My question has to do with the integrity of your clutch. It powers both the HST transmission and the rear pto.
By having an implement like a bush hog on the pto and try and power it when these symptoms occur, if the pto slows or stops it points to you needing a new clutch. For this test the pto needs to have a big load on it not just turning free. Back the bush hog into heavy grass.
It is a bad idea to use other than the best Kubota fluids when you have an HST.
Structuralguy
Kubota B2710 HST
Jan 14, 2023
North Carolina
Were you able to fix your problem, and what was it? I have the same issue and am looking for some ideas… thanks!
No I have not. For now I just limp around in low gear once the tractor is hot. I don’t use it a lot but it’s definitely aggravating. I fear it is the transmission.
9,366
If you don't test it the way we say, you'll never know if it's a simple fix or not.
One other option could be restricted flow through the filters for the HST, there are 2.
spittinfire
NC
I'm going to wake up an old thread because I have the exact same issue with my B2710 except mine doesn't completely stop moving, it just slows way down and I have to use low to climb any type of hill at all.
I've change the filters and fluid using Super UDT2 and it made no difference. I use the tractor a lot for mowing and I can mow through very tall, thick grass and the PTO doesn't slow down at all. At one point I put gauges on the loader valve to see what kind of pressure it was making and while I don't remember exactly what the pressure was it was within spec. Any ideas would be appreciated.
spittinfire
NC
I changed the fuel filter not long ago and the engine gives no indication that it's not getting enough fuel. I can certainly it try it though. The engine actually runs really nice and until it gets hot and slows down it's a great operating tractor.
9,366
Checking the pressures on the loaders hydraulic system has Zero to do with the pressures of the HST.
Do you have the WSM (aka Service manual)?
Chistech
B7510, B2710
Oct 8, 2025
Dartmouth Ma
Hello all, new here. Just got a 2710 HST that doesnt want to move very well. Similar story to everyone else. I changed the fluid and filter also pulled the screen. The diagram shows the screen and the filter on the left side of the trans but i pulled a screen out of the right side. Are there two screens? I did find some gunk with tiny metal filings on the screen but not a ton. If I understand the WSM correctly, I should check my charge pump at either the forward or reverse relief valves on the top of the trans by removing either valve and installing a low pressure gauge. Is that correct?
9,366
Amount of Filter screens would be dependent on serial number.
This serial number series has 2:
This serial series has a spin on filter instead of a screen.
Chistech
B7510, B2710
Oct 8, 2025
Dartmouth Ma
I will get my tractor serial number but it definitely has a spin on filter on the left (driver) side of the transmission. It then has two large tubings , one on each side which go pretty much the full length of the trans tunnel. The right side tube has a banjo type fitting which when removed yielded the metal screen. On the same side as the filter, the tubing, which is identical in size to the right side tube, makes a loop around the spin on filter then also has an identical banjo fitting holding it to the trans case.
In my workshop manual, which I found and downloaded off the internet after I did my oil change, shows a screen in the left side banjo fitting behind the screw on filter. This would mean there is two screens, one on each side at each banjo fitting. The reason I asked is I will now have to drain my trans again to remove the screen but I will have to do that anyway to service the charge pump and trans. I want to check for the left side screen then refill the trans to make sure I get the proper pressure readings.
