Rear Wheels
Alextr
Kubota L3540HST
May 22, 2022
MN
I have a L3540HST. The valve stems on the rear wheels are inboard side and a pain to check.
What would I have to do to put them to the outside?
I asked my dealer from whom I brought it from new and he said they do that to protect the stems. I was thinking that was strange. Then while leaving I see all of them on the outside.
Thanks
6,384
You would need to swap tires from the right to the left to keep the tread direction proper.
BigG
Sep 14, 2018
1,951
770
West Central,FL
You could simply drill a hole on the outside of the rim. Treat the edge of the metal to smooth it and paint it to prevent rust. Then insert a new stem. Now you have a valve stem on both sides of the rim.
  • Dislike
Alextr
Kubota L3540HST
May 22, 2022
MN
Would that change the offset or width? Would the tires have to be remounted?
Thanks
Pau7220
Aug 1, 2017
785
278
Scranton, PA
Mine are inboard for that exact reason. Pulled out many twigs / small branches caught between the rim flange and the wheel. If my stems were on the outside without welded protection hoops, they definitely would be damaged.
IMHO, if you bought it to get it dirty and don’t have hoops, leave them inboard.
You can get an inflator with a whip hose to make life easier.
6,384
Depending on the style of the rim you may or may not have to have them unmounted and remounted.
Normally AG tires and rims are swappable without having to unmount the tire, all you do is unbolt the center and readjust to the proper dish orientation.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,817
2,830
Curious -what "protects" them inboard as opposed to outboard? Aside from the undercarriage of the unit when the stems are not at the bottom of the wheel.
Flintknapper
L2350DT
May 3, 2022
1,767
2,226
Deep East Texas
Yep,
Makes it much easier to inflate the tires.
The one I have you simply press the 'chuck' firmly on the valve (no need to depress anything) and then press the small tab to release when done.
You can inflate or deflate at any time, making it very easy to accurately inflate to a certain psi.
Alextr
Kubota L3540HST
May 22, 2022
MN
Thanks for all the great information. And very fast reply's.
The valve adaptor might just do it.
There's a ton of information on this forum.
BAP
Dec 31, 2012
2,756
869
Yep,
View attachment 93921 View attachment 93922 View attachment 93923
Those only work if you have empty tires without any liquid ballast. If your tires are loaded, those will work 1-2 times before they are ruined.
Pau7220
Aug 1, 2017
785
278
Scranton, PA
My Milton is in excess of 40 years old. Stem at 12 o’clock position. Connect with trigger pulled to clear core before reading gauge.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,411
1,691
Kalamazoo, MI
The only real way to protect valve stems is to weld a 2" pipe nipple around it and put a pipe cap on it like log skidders have. Anything else is marginally effective at best.
Flintknapper
L2350DT
May 3, 2022
1,767
2,226
Deep East Texas
My tires are not loaded but if air pressure is taken as above.....I can't imagine it being a problem.
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
411
199
Randolph county N.C.
Thanks
It sounds like your rims are set in the narrow configuration. You can have the rims set to the wide configuration and the valve stems will be on the outside. You will also gain more stability with the mounting wide. Check owners manual, it should have an illustration of what I am talking about. Would also be a good time to get the tires loaded if you do loader work.
3,316
That's what I was thinking. Lol.
I also cannot imagine any reason to have them mounted inboard rather than outboard…there’s no difference I can see as far as “protection” is concerned. (Damn inconvenient being inboard.)
Swapping-sides by unbolting from the wheel-centers and moving them as suggested by Wolfman astutely suggests is the simplest solution. Welding a pipe-stub protector on also seems good.
Alextr
Kubota L3540HST
May 22, 2022
MN
Yes they are in the narrow position and loaded. Looks like that will work, good idea.
Thank you everyone for the help.
Pau7220
Aug 1, 2017
785
278
Scranton, PA
When clearing brush or debris with a piranha tooth bar, the bucket width is cleared. I also have nothing stuck between my tire and wheel on the inside… outside I do.
