I've got a M7060 and the cab air/heat had been working. Now, everything comes on like it should, but air will not blow with either heat or a/c selected. I've checked all the fuses and they are all good. Not sure what else to look for.
Are you saying there is a relay under the seat?There is a fan relay behind the panel under the seat. Control side of the relay is a 5 amp fuse and the fan power is a 20 amp but you said you have checked them. There are also slow blow fuses at the battery you might check. You could swap relays to see if that is the problem.
Actually there are 2 relays. A "Blower Relay" and a "Blower High Relay". Sitting in the seat, the panel you need to take off is right behind your heels.Are you saying there is a relay under the seat?
Ok, thanks. I will try that.Actually there are 2 relays. A "Blower Relay" and a "Blower High Relay". Sitting in the seat, the panel you need to take off is right behind your heels.
Page 109 in the operators manual shows a drawing of it in the lower right hand corner of the page. It also looks like there are two fuses in there too but I don't know what they for.Ok, thanks. I will try that.
They are for the rear and side window defogger so not the blower.Page 109 in the operators manual shows a drawing of it in the lower right hand corner of the page. It also looks like there are two fuses in there too but I don't know what they for.
Got the air blowing again by replacing this relay. Thanks for the info, I never knew they were behind that panel. Still trying to track down the working light issue.Actually there are 2 relays. A "Blower Relay" and a "Blower High Relay". Sitting in the seat, the panel you need to take off is right behind your heels.
