I've got a Kubota 2301 and want to install hydraulic top & side links. I need some recommendations for this equipment & a recommendation for a remote valve control. Thanks!
30 weeks lead time on the lines! Holy Moley!! Oh, well, it is what it is. Thanks for the info.My recommendation is to get the 2 factory rear remotes and then get in line at Fit Rite Hydraulics for the actual T&T set.
First, do you want or need quick hitch for the 3 point hitch? (Pat's or a frame that uses the top link). I ask since those normally need a 4" longer stroke on the top link....want to install hydraulic top & side links. I need some recommendations for this equipment & a recommendation for a remote valve control...
Apparently notYou guys realize that the OP has a B series tractor, right?
Link range short video clipI'm working with my dealer, on his recommendation, to get a new offering from Land Pride for a top an tilt kit. No word on timing yet (initiated order about a month back.)
Land Pride
www.landpride.com
Well, I hope that the set you get works like that video having the stroke of the rod around half way extended when the implement is level, both front-back for the top link as well as side-side for the side link.
