MX4800
jwcanaday
MX4800
Dec 16, 2018
Spencer Ok
I have a MX4800 that i bought in 2018, brand new, and it has 300 hours on it. I'm having issues with the loss of power. When driving in High or Low it doesn't to matter which gear I'm in just doesn't have the power it had in the recent past. Talked to the company I bought it from they believe its the clutch. I adjusted the clutch and its better, but still doesn''t have the power that it has before.
zfish65
None, Kubota Parts Specialist
Dec 27, 2022
Fleetwood
Hows the fluid level? Are the relief valves working properly?
Grandad4
Apr 5, 2016
325
80
Greensboro, NC
Loss of power could mean several things. It would be helpful if you could share some more detail. Like how is the engine running... sounds normal or not, running hot, smoking, etc. Or does the engine seem Ok but the tractor doesn't have enough pulling power? What type of transmission does it have? Are the hydraulics working normally? Etc. Also, could the winter weather be a factor for your location?
6,401
Yea what he said!
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
Further detail would be good but before going too far into it check your air filter, fuel filter, and make sure you have good fuel flow into the filter.
