Alfred_2345
L3901, LA525, BH77, SGC1060, RZ60, Box Blade, Z726XKW ZTM, RTV-X900
Hi,
New member that recently bought a used L3901 with LA575 FEL and BH77 backhoe. I don’t have any experience with tractors but I am an electronics engineer so I have some technical background.
The previous owner had installed a Land Pride 3rd Function kit. I picked up a used SGC1060 grapple that was not originally associated with the tractor. (Hoses were longer and had wrong couplings.) I replaced the grapple hoses & couplings but the grapple won’t operate. After reviewing the workshop manuals, various YouTube videos and tracing out the hose connection to the 3rd Function valve, I believe the previous owner installed the 3rd Function incorrectly. See “Existing” picture. Port names are per the Kubota manuals.
I could not find any installation instructions or videos for 3rd function valves that include a backhoe. I tried to find any relevant posts here but the search terms are too generic. I want to hook up the 3rd Function value as shown in the “Proposed” image (uses the existing hoses in place and just changes the connections at the hydraulic block).
Will this work?
From what I have learned, FEL, BH, & 3rd Func should be “in series” (i.e. one after the other in the circuit) and order shouldn’t matter. (In the future I plan on rerouting the hoses to eliminate the elbow and one hose. That routing would place the 3rd Func. in the circuit between the FEL & BH. But I first want to get things working.)
Second question: As I don’t know the history of the grapple, I don’t know what type of hydraulic fluid is in it. Is this an issue? Do I need to drain the cylinders so I don’t contaminate the tractor hydraulic fluid?
Thanks in advance,
Alfred
Will this work?
Thanks in advance,
Alfred
