The OEM kit is much better integrated and uses mechanical rather than electro-mechanical valves. The usual concern with the Kubota option is the cost. How does that compare?Factory kubota rear remote kit or summit hydraulics kit. What is everyone's preference?
I think its about 1100 for the gactory kit and 700 for a 2 spool summit kit.The OEM kit is much better integrated and uses mechanical rather than electro-mechanical valves. The usual concern with the Kubota option is the cost. How does that compare?
You can add a manual two spool valve for even less.I think its about 1100 for the gactory kit and 700 for a 2 spool summit kit.
There is a hydraulic outlet on the side of the transmission. It has two ports - pump OUT and power beyond return and is normally used for the loader valve. You can easily add a AUX valve by rerouting the power beyond return hose from the loader valve to pressure IN on your AUX valve and then connect power beyond on the AUX valve to the power beyond return port on the block. If you don't have a loader valve you would need to buy the outlet block 7J612-68110 ($97) and plumb the AUX valve directly off those ports.I would get the installation instructions first and then decide what has to be done to properly install it on your tractor. What surprises me is that Kubota doesn't make a kit available for the BX23S.
After looking at some parts diagrams it appears the OEM remote valve mounts directly on the tank return port used by the backhoe and is also plumbed into the power beyond return port used by the backhoe.Dusty.... Ask Kubota WHY not ( it should be just 4 hoses and a 'block' ? ). Offer to be their 'tester'..
hmm..
dang nab it...
forget that !
I'll email them tomorrow and see about getting my free dual rear remote for BX23S kit !!![]()
What sort of tee in the PB? That is a no-no.I’m in the process to install the remote kit on my Bx23s. My plan at this time is to install Ts in the supply and PB lines of the remote kit. The I plan to fabricate a new dip stick that will have a fitting for the return line as well as a smaller dip stick to be able to check fluid level. Won’t attempt all of this until the weather gets warmer and no longer need to use the snowblower.
Well the plan is to put the tee in the hard line between the rear remote valve and where it terminates in the FEL connections behind the R rear tire where the PB was connected for the backhoe. I then would adapt the PB hard line that was removed to feed the coupling for the backhoe. Appreciate your comment and look forward to your explanation why I should not do this. Just trying to figure out the way to have both the rear remote kit and the backhoe connections.What sort of tee in the PB? That is a no-no.
Just some additional info on my plan. I would only plan to use the backhoe connections with the backhoe or 3pt log splitter as I currently do. The rear remotes would be used with the 3pt to have tilt and trim on my box blade,York rake, or rear blade.Well the plan is to put the tee in the hard line between the rear remote valve and where it terminates in the FEL connections behind the R rear tire where the PB was connected for the backhoe. I then would adapt the PB hard line that was removed to feed the coupling for the backhoe. Appreciate your comment and look forward to your explanation why I should not do this. Just trying to figure out the way to have both the rear remote kit and the backhoe connections.
Power beyond must be one continuous circuit where each valve feeds the next in the series. You cannot branch it to feed multiple devices in parallel - that will give you two paths to tank via the center circuit and you lose pump pressure to ALL down stream valves. Go back and read what I said earlier in #11 about the backhoe and remote PB connections.Well the plan is to put the tee in the hard line between the rear remote valve and where it terminates in the FEL connections behind the R rear tire where the PB was connected for the backhoe. I then would adapt the PB hard line that was removed to feed the coupling for the backhoe. Appreciate your comment and look forward to your explanation why I should not do this. Just trying to figure out the way to have both the rear remote kit and the backhoe connections.
Here are the part diagrams for the FEL valve plumbing, Backhoe plumbing, and the remote kit plumbing. Exactly how are you planning on putting these together?Well the plan is to put the tee in the hard line between the rear remote valve and where it terminates in the FEL connections behind the R rear tire where the PB was connected for the backhoe. I then would adapt the PB hard line that was removed to feed the coupling for the backhoe. Appreciate your comment and look forward to your explanation why I should not do this. Just trying to figure out the way to have both the rear remote kit and the backhoe connections.
I think you will find that does not work. If you put a tee in the 110 line you will have two paths to tank and no pump pressure beyond that point. Your plumbing is close but not quite right.Dan,
Hope I can explain. In the second diagram the existing (supply)hose #150 gets removed and is replaced with the (supply)hard line #110 in the rear remote kit diagram. I would plan to add a tee in the #110 line where I would connect the #150 hose to supply the backhoe.
The Hard line #120 pipe in the kit connects to what I think is the (PB) for the FEL. I would put a tee in this line that would allow me to connect the female coupler #140 which would be used for the backhoe connection which I also believe is (PB).
Since the kit #020-#040 connection eliminates the (return) line from the back of the BX. I plan to make a new trans oil dip stick that would incorporate a fitting to connect the (return) line from the backhoe.
I think I understand your concerns with the (PB) but I do not plan to use the Rear remotes with the backhoe attached. If I plumb a hydraulic thumb, I plan to add that control valve into and on the backhoe control circuit which I have not figure out yet, but it would be disconnected when the backhoe is removed. I think I need to put a (PB) fitting into the existing valve to be able plumb the new thumb valve and the back to the (PB) coupler on the back of the BX.
This a little lengthy but hope you can understand. Sorry I may be slow replying to your replies but I'm not getting notices when I get updates so only see your replies when I log in.
I hope you can give me direction on my plan to allow me to use both connections for the backhoe and rear remotes. I appreciate you sharing your knowledge with me!!!
