How is the B3030HSDC
ANTONj
B2400
Aug 31, 2022
Ballston Lake, NY
It seems one of these would work for me for snow blowing. When did they start emissions (if they did?) so I know what year model to focus on buying?
number two
B3030HSDC L2501HST
Mar 26, 2021
393
182
Northern Lower Michigan
B3030HSDC made from 2006-2012.
Minimal Tier 2 emissions.
Great snowblowing machine!
Successor models B3000 & B2650 also minimal emission equipment.
Good luck!
Michford
2018 Kubota B2650HSDC
Aug 24, 2022
21
29
I had a 2006 B3030HSDC with a 51" wide B2781 front blower that I sold when I upgraded to a 2018 B2650HSDC with a 63" B2782 front blower. The B3030 is a very capable snowblower tractor, and the B3030 will not have any of the emission and regen crud on it. The B3350 replaced the B3030 and had emissions on it as it was 30 hp. I believe anything above 26 hp was the cut off for emissions. Just make sure any B3030 you find already has the front blower with it as it may not be cost effective to find a subframe and front blower after you get a tractor.
10,003
Does the HSDC designate the enclosed cab? That is preferable for snow for me obviously.
There is 2 cabbed models,
HSDC = Standard cab
HSDCC = Deluxe cab
ANTONj
B2400
Aug 31, 2022
Ballston Lake, NY
And a L5030 is a pretty good bet as well with a cab? I might have a chance to get one of those big bears, seems to be early part of the century pre emissions and a 72’“ blower. Anyone have experience with those?
ANTONj
B2400
Aug 31, 2022
Ballston Lake, NY
Currently I have a B2400 from late nineties that has the rear PTO blower and I am sick of that turning around nonsense. Also no cab and I dont know what blower setup would fit on that for the front. I would probably keep the small one handy with the bucket on the front in the winter and the rear blade on the three point for touching up As I need to back drag heavy snow that comes off the roof in front of the garage doors that may not be easy to blow. I never see anyone with a front blower have a rear blade on the back. Is that something that is impossible or not practical?
imnukensc
BX2380
Sep 10, 2015
769
728
Midlands of SC
God, I love to read about you guys snow blower issues because I don't deal with that crap. Think about moving to the southwest. That's my advice.
Michford
Aug 24, 2022
21
29
Lots and lots of folks run a front snowblower and a blade of some sort on the rear three point hitch. You can run a back blade or a box blade.
RMS
Sep 26, 2021
288
630
Buckfield Maine
I have a front snow blower and a rear blade that I bought just to be able to drag the snow that falls off of the roofs and is close to the buildings. It works great. It also comes in handy when the snow is too wet for the blower and tends to clog the shute.
ANTONj
B2400
Aug 31, 2022
Ballston Lake, NY
Yes, this is my idea of how to handle that exact same set of issues. I just rarely see it, in upstate NY the show is often wet. Some winters it is a freezing wet sleet. It isn’t usually powder like the Rockies outside of a couple of times. I have SSQA on my loader and put a push bade on front and rear blower on and off all set to go but the issue I run into is that the turning backwards and steering around the bends in the driveway is a drag on my body, not to mention the wind blowing the snow back into my face! Sometimes I just jump in the plow truck and raise the blade Because I have gravel. But it still makes a mess. Ultimately I want to get rid of the plow truck. A larger tractor and cab with a front blower and a back blade might solve the issues.
3,337
I'm not sure if it makes any difference to the OP, but if I remember right, the B3030 has a hydraulic clutch, rather than a standard foot operated clutch, which I personally dislike, having a hydraulic clutch on my BX but not on my B2910.
Just thought I would mention this, as he is moving up from an older tractor that I would bet has the standard foot operated clutch. Might make no difference with a snow blower, don't know. But I would hate to use a post hole digger on my BX.
I actually cringe every time I turn my mower deck on with the BX...not as much as I used to though, now that I learned to do it at higher engine RPM.
PaulL
2,678
1,671
NZ
At higher engine RPM? I always start my mower at about 1,500 rpm, then throttle up. Reduces the load starting it (at least in my mind). However, I assume the clutch in them is rated to far more uses than I'll ever put on it.
Michford
Aug 24, 2022
21
29
The B3030 is fully hydrostatic, there is no clutch.
3,337
Might just be semantics, but I thought when the PTO is selected, a clutch was operated hydraulically, but there was still a clutch. Never looked into it though, so I could be wrong.
Michford
Aug 24, 2022
21
29
I cant say for sure either after more thought, and I have never looked into it either.
crbr
2006 B7800, 2022 BX1880
Jan 8, 2010
34
25
TN
In your quest of looking for the 3030 (or similar), don't necessarily pass up an older (same era) B7800. Same machine (30 HP) and reliable. I have a 2006 year make (275 hours currently) and it does not have emission gadgets. It is also an open station seating unit, but I also do not have to blow snow.
US $0.02
