Kuboda power angle snow blade attachment
alexdelam
Dec 31, 2022
Northern Ontario
I have a 2021, 2610 kubota tractor with a bucket assembly. I just recently purchased a snow blade that connects to the boom. It has power angling that will work off of the boom controls. I will still be able to lift the boom up and down but use the bucket role control to use the power angle on the blade. My problem is where to connect the two hoses from the blade to the tractor. The connections on the tractor are colour coded and the manual tells me that if I hook up the wrong ones I will damage the hydraulic pump. Can anyone help me with this?
jkrubi12
B2601/LA435/QA54"/BH70/B8160box/BB1254/PFL1242/SGC0554/WC-68 Chipper
Sep 24, 2012
400
291
right coast
Do you have a third function valve on your tractor? If you've taken off a quick-attach (SSQA) bucket (not pin-on, SSQA (Skid Steer Quick Attach, assumed to be almost standard on a 2021 B2610)) then your bucket curl cylinders won't work your blade angle, just curl/dump the blade assembly. If your'e planning to angle the blade by attaching the blade's 'hoses' to the bucket curl/dump cylinders, while that may be possible I'm not sure it would be recommended.
If you do not already have the third function setup on your FEL (Front End Loader, which is what I believe you are referring to by the term 'boom') you may want to add that functionality to make the blade attachment setup complete (at an estimated cost of $1500).
4,668
You connect it in place of the bucket hoses. Just follow them from the front to the back.
