Hey guys, I've been considering upgrading my current portable gas powered generator. What are your opinions on PTO powered generators? Anybody have one? Anyone running a Baumalight Generator?
Mike
Mike
I’m not an expert on generators or much of anything else, nor do I play one on Internet forums. What I do know about the specific PTO generator I have, some of which may be applicable in general:Thanks for the responses!
What is required to service a PTO powered generator? Do you just need to run it on occasion?
Mike
Unlike gas/diesel/etc. generators, not much other than cover and put it in a garage with the rest of your tools. Everything stores better in climate controlled spaces, but most don't have them. Check the gearbox oil level every time you take it out to use. BTW, the IMDs are made in Italy and finished up in North Carolina. They are brushless. Advise using a makeshift cover when operating in the rain. I also drove a ground rod near my 50A feed point and have a clamp on strap.Thanks for the responses!
Mike
Nice! I have a similar generator-ready setup installed on my home. It works great!I have a 12kw Baumalight that I run with my B2920. Works good and runs everything we need in the house. I have an outside plug box on the side of the house that I plug the cord into. In the basement in my breaker panel I have a Generator Interlock switch.
I'm pleased to hear that maintenance is easy but, I'm concerned about storage in my climate. I'm thinking the generator would very likely be outside and we get tons of rain. Do you think that'll be an issue long-term?Unlike gas/diesel/etc. generators, not much other than cover and put it in a garage with the rest of your tools. Everything stores better in climate controlled spaces, but most don't have them. Check the gearbox oil level every time you take it out to use. BTW, the IMDs are made in Italy and finished up in North Carolina. They are brushless. Advise using a makeshift cover when operating in the rain. I also drove a ground rod near my 50A feed point and have a clamp on strap.
No but keep it well covered. If you make a small crib out of a pallet, You can put it at perfect grab height while keeping water and mud from migrating in due to wind.I'm pleased to hear that maintenance is easy but, I'm concerned about storage in my climate. I'm thinking the generator would very likely be outside and we get tons of rain. Do you think that'll be an issue long-term?
Mike
Yes it is the Baumalight 12kw. Bought it 10 years ago when we moved here because at our last house, we lost power a lot. There we had wood heat and a generator for our water supply because it also fed the cows. Here we don’t have either of those so I wanted to have our own generator. Turns out, power rarely goes out but when it does, it is nice to have it particularly when it is quite cold outside.Nice! I have a similar generator-ready setup installed on my home. It works great!
I'm assuming you like the Baumalight 12kw? That's the unit I'm considering for our home.
Mike
I had a 135 for a few years, it was a great tractor. A big step up from a N series ford.I have a 16kW IMD AVR that I hook up to my 60 year old Massey 135 diesel. I only put a load of about 20 amps on it and the tractor and gen handled it fine.
I have a 4#4 cord with 60 amp plugs on both ends. I took a 50 amp RV plug and replaced it with a 60 amp plugs and screwed it to the side of my Kohler transfer switch. I also have a manual transfer switch to wire it in directly.
They import the generator head from Italy, they showed me the tracking of the ship. They assemble, test, and add the outlets.
I bought the 3 point carrier and pto shaft from IMD but you could make your own if you have a permanent location.
I need to get rid of it, it just sits since it doesn't have a loader. But I can't do it.I had a 135 for a few years, it was a great tractor. A big step up from a N series ford.
Typically generators that produce more than 6% THD (total harmonic distortion) are "dirty". The inverters made by Winco, IMD, and others are brushless and produce <5% THD. Also, some like my IMD, have "Automatic Voltage Regulation" (AVR) do more to keep voltage stability, which lends itself to more sensitive electronics. This is beyond what a capacitance regulation scheme does. The inverters are much more closer to pure sine wave as well. Cheap generators produce a modified sine wave which can play havoc on electronics. Make sure you size correctly as motor starting loads draw more amps and can result in voltage drops. It's the main reason refrigerator motors are burned up with undersized products. As the voltage drops, current spikes and will burn through the windings. One nice feature of the AVR units is considerably more surge (motor starting) watts. My 10KW is rated at 20KW surge. That's much more than a standard capacitance regulation. It's every bit as clean as my big Kohler automatic 14KW whole house unit. Never a hint of an issue. When sizing for a home, ASSUME that every refrigerator, freezer, furnace, water pump, or whatever will at some interval all decide to start at the same time. There are good online calculators out there which can help. AVR gives you more latitude. Since you have a 3 point hitch, no need to go for less weight on the inverter armature. Heavier ones have more momentum and can also help deal with starting loads.How dirty is the voltage in these PTO driven units you folks are speaking of (?)
