no need for ballast?
Billbo
B2320 HST
Jan 4, 2022
62
South Louisiana
good morning first i hope all had a wonderful Christmas and will have a Happy New Year
i have a small kubota B2320 i have the rear tires filled. My FEL will not come close to lifting the back tires off the ground. to me that means i do NOT need any extra ballast OR my FEL is not lifting to capacity???? Any comments or suggestions appreciated
Thanks, Bill
4,908
curious...according to tractordata, your machine should be able to lift 500-750#,though that includes bucket weight....
so how much weight have you tried to lift ?
if you can 'max out' the loader lifting capacity without having rear wheels get airborne, you should be fine.
caution though, always keep bucket close to the ground,NEVER drive with a load way up high !
You'll soon remember High school Physics real fast...
Billbo
B2320 HST
Jan 4, 2022
62
South Louisiana
thanks for your reply. ive just read so much about having 'ballast boxes' etc filled with 500-1000 pounds when using FEL -- i think perhaps my little tractor is not lifting to its capacity (or its capacity is very lacking)
Billbo
B2320 HST
Jan 4, 2022
62
South Louisiana
I have also read where others compact tractors WILL lift rear tires off ground without proper ballast. I think I might have a problem
rc51stierhoff
3,083
Sort of depends on what doing, how doing it, and the terrain…maybe it’s a non issue for your tasks and terrain? Here is an interesting article…
Billbo
B2320 HST
Jan 4, 2022
62
South Louisiana
thanks for your reply and info. question - when put under an immovable object, do all tractors FEL lift rear tires off ground with NO ballast???
rc51stierhoff
3,083
Well, I am sure some might try to answer, but when you say ‘all’ tractors…I suspect none have experience with ‘all’ 😉. I think it depends on the loader capability and the weight of the machine(s)….so I think it hard to say for ‘all’…IMHO.
Also keep in mind ballasting can be necessary whether or not you have or are using a loader….it’s about keeping the rubber side down (keeping the machine balanced and tires planted on the ground).
Billbo
B2320 HST
Jan 4, 2022
62
South Louisiana
thank you --- and i understand --- just thinking my FEL may be lacking in some way. Not sure how to 'test' the lifting capacity except by placing known weigh inside the bucket and try to max it out that way??
i probably just need a stronger tractor!!!
rc51stierhoff
3,083
Well to determine your machine matches the spec, that seems like the way to check…another gauge (it’s less scientific) would be if it t can lift a full bucket or dry soil…it should be able to do that I would think…but if the soil is wet it t might struggle a bit…I am not sure but that is the way my B seems to be…it does fine when everything dry but then really wet soil sure makes a difference in what it can safely scoop/transport…I don’t have any data though to say if it’s in spec, its just what I notice. My machine is usually tippier from the terrain IMO…especially if using forks and a heavy load…machine gets really tippy (front heavy).
Steve67
B2601-fel, 60"mmm, 5' rear blade, balast box
Jan 20, 2017
344
128
St. Louis, mo.
Using rear ballast also helps taking pressure off front tires and front axle components
4,908
to test it's capacity is easy...
acquire several solid concrete blocks
weigh one block or get weight from internet...
place it in bucket
add 4 more
lift it up 1' off the ground
lower
repeat adding/lifting/lowering until it will not lift them
count the blocks ,multiply by the weight of one, there's your answer
BTW a cubic foot of concrete weighs about 150#.
if the tractor 'teeter-totters', you need more rear 'ballast'
Billbo
B2320 HST
Jan 4, 2022
62
South Louisiana
Thany You for your reply.
place it in bucket
add 4 more
lower
Thank you for your reply. makes sense to me - will give it a try
Thanks for that info.
JeremyBX2200
BX2200
Aug 3, 2020
466
436
Indiana
You could get a hydraulic pressure gauge to make sure your bypass is set to the correct pressure. If it is low it will reduce the weight you can lift.
I have a BX2200, so a little smaller that yours. I need ballast when spreading topsoil and gravel. I currently use my box blade for ballast and it seems to fit the bill.
torch
Jun 10, 2016
2,619
869
Muskoka, Ont.
The purpose of rear ballast is not to keep the rear wheels on the ground -- if they come off the ground you are way past the point of needing rear ballast.
The purpose of ballast is a) lower the centre of gravity, b) shift weight to the solid axle to prevent roll-over and c) to prevent overloading the front axle.
Loading tires is the most effective means of accomplishing a) and to a lesser extent b).
Adding weight to the 3ph helps a) somewhat, significantly helps b) and is the only way to accomplish c).
BigG
Sep 14, 2018
1,951
770
West Central,FL
When you are using the FEL you need to have rear ballast. The tires lifting from the ground is not a good gauge to measure the need of the ballast. The ballast will help insure good braking, lower the center of gravity, and transfer the weight in the FEL to the rear axle. These are all good reasons to keep the extra weight on the rear of the tractor. The 2501 will also need rear ballast when using the FEL.
ve9aa
Apr 11, 2021
1,202
982
NB, Canada
You need rear ballast.
2,968
I think the verbiage accented in blue above is misleading.
A MAJOR purpose of rear ballast is certainly without question to keep the rear wheels on the ground. If they come off the ground, all bets are off as to the net result, which could be bad. If the rear wheels come off the ground, you need more rear ballast for certain. (Unless we are talking about driving across a slope. Then rear ballast will not help much other than possibly lowering the center of gravity)
Loading tires causes no shift of weight to the rear axle, since the tire is centered on the rear axle. It certainly does add to stability as the net result is a lowering of the tractor's center of gravity, and it works to counter the pivoting action at the front axle when lifting with the loader.
Other than these two points, what Torch says is true in my mind.
Billbo
B2320 HST
Jan 4, 2022
62
South Louisiana
i may (probably did) state my concern incorrectly. Actually, I would love to have my rear tires come up when lifting the FEL,indicating it is lifting with gusto, but since that doesnt happen, is it possible my FEL is just WEAK? for example, what IF my FEL is rated to lift 1000 lbs and it wont even lift 100 lbs? Id say ballast wouldnt help me and i do NOT need any ballast, I need my FEL fixed!
