Shop manual for a LX2963
Oldmanbs
LX2610HSDC, LA535, LX2963, Land Pride back blade, B-422 tiller, posthole digger
Jul 27, 2021
14
Buffalo Minnesota
Anybody know where I can get a shop manual for a lx2963 snowblower on my lx2610hsdc, I’m happy to purchase it. The input shaft broke inside the front gearbox, and no the kubota shear pins did not break, the shaft broke where it steps down inside the gearbox, and I need to know how it comes out, the new shaft is coming tomorrow. Thank you in advance for any help provided. Brian.
zfish65
None, Kubota Parts Specialist
Dec 27, 2022
Fleetwood
Theres going to be a c-clip at the end of the shaft, inside the gear box.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
927
721
canada
I would say remove the three (#100) screws, the end plate, then the whole works should slid out.
zfish65
Dec 27, 2022
Fleetwood
Anybody know where I can get a shop manual for a lx2963 snowblower on my lx2610hsdc, I’m happy to purchase it. The input shaft broke inside the front gearbox, and no the kubota shear pins did not break, the shaft broke where it steps down inside the gearbox, and I need to know how it comes out, the new shaft is coming tomorrow. Thank you in advance for any help provided. Brian. View attachment 92937
I thought this is what you were referring to. Take out #100 screws and start from there. Theres 4 key ways. One on the smaller shaft and 3 on the bigger. they play a big roll of holding everything in place.
BessemerDave
LX2610
Dec 29, 2022
Bessemer MI
Looks like I am in the same boat. What is with these shafts? Recall!! - Oldmanbs let me know how it turns out. This fix might be above me, so off to the dealer I go.
Oldmanbs
Jul 27, 2021
14
Buffalo Minnesota
Really wasn’t that hard to replace but had to disassemble both gear boxes as the gear inside the reduction box was all but rusted to the shaft and keys. But good thing I had ultra gray RTV as that is what seals both. I removed the whole auger assembly as that came right off then piece by piece worked my way back. Needed two qts of 80w90 gear oil dealer was as good a price as parts store, And yes must be happening a lot as the dealer had one in stock….. but no monetary help from Kubota dealer.
Oldmanbs
Jul 27, 2021
14
Buffalo Minnesota
Mine was rusted in had to disassemble the reduction box to drive gear off shaft. But shaft goes backwards out of the front box after the keys are removed.
