OK - that EA coupler is a Safeway S40 series coupler
Got all excited when I read this and ran out there to try it... sorry to say no luck.... boohoo!OK - that EA coupler is a Safeway S40 series couplerand does not interchange with the S20 series on your old grapple. You will need to replace something and the easiest is going to be the couplers on the EA grapple.
Edit: Scratch that!! After checking the Safeway catalog the S40 and S20 are both listed as AG couplers and use the exact same nipples. The difference is the S40 female is a two way sleeve push/pull to connect coupler. I use them a lot and should have remembered that. Are you sure you are getting the sleeve locked? You don't retract it to connect - it actually extends to connect. Just grasp the sleeve tightly and push it onto the nipple and then let go - it will lock automagically.
SKIP THIS BRAIN DEAD RESPONSE AND SEE MY FOLLOWUPGot all excited when I read this and ran out there to try it... sorry to say no luck.... boohoo!
And no the sleeve doesn't feel like it is locked, has about an 1/8" slop push pull but it doesn't come off....
Not sure what to do next... Tried both ways, retract to connect and push pull, same result....
I seem to be having a senior moment.Got all excited when I read this and ran out there to try it... sorry to say no luck.... boohoo!
Thanks and I do appreciate your help and patience!I seem to be having a senior moment.
Your old couplers are SH20 series couplers NOT S20 series. I had it right the first time and got my wires crossed when I started looking at the catalogs. The SH series couplers do NOT interchange with Safeway S20 or S40 or any other series agricultural couplers. The 6000 PSI pressure rating on your old couplers finally got me back on the correct catalog page.
So back to my original response - you have incompatible couplers and need to replace something. Replacing the S40 couplers on the EA grapple with matching SH20 couplers is the cheapest way to go.
My apologies for the side trip down Dementia Lane.
New dementia test?Thanks and I do appreciate your help and patience!
My best course of action is to take the couplers off my old grapple and install on the new one.
One thing I know for sure this has taken up way too much time and need to get a resolution!
Only problem with my solution is I can't get the couplers to budge! What's the trick to getting them off?
If I get the old couplers installed on the new grapple then I just need to buy replacements for the old one and may not even do that if I sell it. Anyways How do I get them off? Thanks again!
Something else to look at..... sheesh!New dementia test?
If I have the part numbers correct the old couplers have SAE6 end connections and your new ones are 1/4 female NPT. They wont swap without the correct adapters.
Which couplers wont budge - old or new?
Careful - I am a virile 71 myselfSomething else to look at..... sheesh!
Anyways I can't get ANY of them to budge!
Might have to do with being 71....
Glue in I think, sealant on all of them.... use heat?Careful - I am a virile 71 myself
Two open end wrenches close together and pull opposite directions.
The SAE adapter in the old couplers should come out easily. The male pipe ends screwed into the other couplers may be glued in....
Should not be anything on the SAE threads. Heat and o,-rings dont play well together. Vise and a pipe wrench / cheater if they are real stubborn.Glue in I think, sealant on all of them.... use heat?
FINALLY got the connectors off! And yeah they have adaptors they used that are different, I’m not up on threads, I used to know…. Need SAE to npt? Help please!Should not be anything on the SAE threads. Heat and o,-rings dont play well together. Vise and a pipe wrench / cheater if they are real stubborn.
If I correctly remember what we discussed you have 1/4" female pipe hose . I would suggest a couple of these - SAE port to female pipe swivel. Easy to connect and no sealant needed on either end.FINALLY got the connectors off! And yeah they have adaptors they used that are different, I’m not up on threads, I used to know…. Need SAE to npt? Help please!
6900-06-04 | #6 SAE/ORB Male x 1/4" NPSM Female Swivel
Check out the deal on 6900-06-04 | #6 SAE/ORB Male x 1/4" NPSM Female Swivel at DiscountHydraulicHose.comwww.discounthydraulichose.com
