I have an L4701. I have had it at a farm I have doing some bush hogging and had left it sit for the last 5 days. We had major rain and a temp drop since I ran it last.
When I started it up today after it had run for about 5 minutes and I was doing my walk around I noticed antifreeze leaking from the top hose that runs from the radiator to the engine at the engine side.
I check the clamp for tightness and hose for leaks and the only thing I can come up with is somehow it got past the clamp even though it was tight. The last time I ran it I ran it hard, this is heavy mowing.
Coolant resivoir is just below the full line when cool.
I turned it off. Checked it for obvious sources and clamps and then turned it back on. After running for about 10 minutes the leak stopped completely and did not leak at all for the rest of the day.
Any ideas what’s going on? And what I need to do? I mowed for about 4 hours with no further leaking or fluid loss.
Im posting the pics for reference. This is after I had cleaned the fluid off so none visible.
