Need to bleed hydraulic lines for new attachment?
milanmark
B2601, Bucket, Grapple, Brush hog, stump bucket is ordered!
Jul 7, 2021
80
40
Milan, MI
Got my new EA Wicked root grapple.... hooked it up but doesnt work....
Swapped the hydraulic lines from my 3rd function hydraulics still no go...
Will call EA tomorrow but thought I would try you guys also. Any advice?
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,411
1,691
Kalamazoo, MI
I've never had to. Just activate the function several times and the air will bleed out of it quickly. Methinks you have a different issue.
MountainMeadows
Jun 6, 2022
222
303
Poconos, PA
I had no issues with my Wicked 55 when it arrived. Basically it was plug + play.
Is there an in line fuse on your 3rd function switch?
2,817
1,534
Assuming there's not some kind of shipping stop installed, there's not much on a grapple not to work. Check the couplings.
Otherwise the issue must be in the third function. Is it new? What kind?
Siesta Sundance
Oct 23, 2022
1,555
1,954
youtube.com
Couplers/Lines reversed??
milanmark
Jul 7, 2021
80
40
Milan, MI
I swapped the lines, no difference...
I had my old grapple on and did some minor work with it... 3rd func was fine.... I'll give them a shout in the am, thanks guys!
top gnome
Dec 12, 2021
461
218
Fundy shore nova scotia
I had a bad coupling on mine that made it not work at high rpm the dealer changed the coupling and it works great now.
milanmark
Jul 7, 2021
80
40
Milan, MI
I need to look more closely at the couplers and if the lines look pressurized... might swap out the couplers on my old grapple see what happens...
milanmark
Jul 7, 2021
80
40
Milan, MI
Coupler issue. It fits but slightly different and fluid not flowing. Top is the one on my old grapple, bottom is my new one. You can push pull a little after new one connected. Frustrated as not sure what to do… right now use my old one!
4,506
Get the part numbers off both couplers and post them here.
4,506
One looks like a Poppet style and the other looks like Ball style.
As long as they are the same series and size that should not matter. I have some of both style here and they interconnect fine. Sounds more like they are differrent series or size. Part numbers will tell that story.
mdhughes
L3901DT
Dec 10, 2014
1,252
722
Ste Geneveive county, MO
As long as they are the same series and size that should not matter. I have some of both style here and they interconnect fine. Sounds more like they are different series or size. Part numbers will tell that story.
I have read where some people have problems mixing them, so I wanted to point it out to the OP.
milanmark
Jul 7, 2021
80
40
Milan, MI
Had some issues posting pics but here is the male connector on the tractor
milanmark
Jul 7, 2021
80
40
Milan, MI
Had to leave for a bit sorry!
pic of part number on old grapple (works)
