@mcmxi
Looking at the second picture I would suggest you see if the implement pins could be turned to the inside of the implement frame so the lower 3 point arms are able to be closer together and farther away from the rear wheel chains.
That implement looks about as wide as you could possibly use with that wheel spacing. I think I would have trouble getting the lower arms out far enough to get onto the pins.
On my small L185 I almost always have to arrange for the pins towards the inside to make it easier to fit, but it has the disadvantage that the stabilization turnbuckle has to be as long as possible when putting the arm onto the pin.
