Anyone that needs to be told to clean things like this should find a different hobby.Maybe you had better re-read your manuals because it tells you to clean the couplers before connection for both styles.
Lol not a hobby, I'm a farmerAnyone that needs to be told to clean things like this should find a different hobby.
Fair enough although with how sensors, def pumps and everything electronic likes to fail on these things eventually I doubt it about that last statement. Mainly sensorsI know some local farmers that keep their tractors going until they can no longer keep them going. They are worked hard but are also kept in tip-top condition, and look as good as the day that they bought them. They make their living as farmers, and a tractor is a tool to do work quicker and easier, so they take care of them just like they take care of their herds. Instead of using your hand to wipe off the coupler, use a clean cloth. It just takes an extra second or two to do it correctly as it does to be sloppy about how you couple them. In the long run, that will save you money. Who knows, if you take care of the tractor, it might be the last tractor that you will ever have to purchase.
Definitely not as good as the regular style, I'm gunna figure a way to swap them outHi shadow, here's a pic of the couplers on my Quicke loader.... View attachment 91567 View attachment 91568
They are 'Faster' brand. There are O ring kits available but I'm not going to bother taking one apart not knowing the timeliness to get the right ones..... I can't quite tell where they leak from when coupled,but they do a bit...
Have you replaced the O-rings? All Pioneer couplers are not made the same. If these are original with the tractor, I would think they are good, but O-rings are a consumable item. The more the couplers are used (connected/disconnected), the faster the O-rings diminish.I unhooked and reattached a couple times yes.... tried everything I could think of to help them out and they just keep leaking. They look fine... the irony is in my life I have never had one of the standard quick couplers leak like that... the normal amount on attaching and removing but that's about it. The only time I had to push them on a bit harder was when I put the loader on, it had settled some and was under slight pressure... but that was only 1 of the 4.. the rest went on easily.
Why do you so often phrase things that ridicule people like that…?Obviously, you have no concept…..
The Tractor Supply I visit only handles Genuine Pioneer:….. Don't buy the cheapest set at Tractor Supply.
Northern Ontario:So, these flat faced male couplers have replaceable O rings..... the females do not, unlike the ' normal' style. And, the p/n from ALO for one seal kit is $112cdn..... lol. Parts guy said just to replace the fittings.... ya right.... at $120+ each (x8). That's a lot of oil. Mine haven't failed from dirt. And are only 4 years old, with maybe a dozen connections......
If they were on the snowblower that would mean they'd only have made 2 connections for those 2 years we had a summer and it didn't snow in all 12 months!Snow blower on....snow blower off .....x 4 years?
"didn't snow in all 12 months"If they were on the snowblower that would mean they'd only have made 2 connections for those 2 years we had a summer and it didn't snow in all 12 months!
Mine were replaced under warranty, tech told me the type kubota uses leaks alot and he replaces them all the timeSo, these flat faced male couplers have replaceable O rings..... the females do not, unlike the ' normal' style. And, the p/n from ALO for one seal kit is $112cdn..... lol. Parts guy said just to replace the fittings.... ya right.... at $120+ each (x8). That's a lot of oil. Mine haven't failed from dirt. And are only 4 years old, with maybe a dozen connections......
