I just purchased a used RTV-X900 and I plan to change all fluids before I use it much. Can you help me with?
1. The manual says the hydraulic oil needs to be changed every 200 hours and the reservoir holds almost 5 gallons. This seems to be overkill to me. The only thing operating from the hydraulic oil reservoir is the lift bed, isn't that correct? Does this oil need to be changed and if so how often?
2. According to the manual, the transmission has 2 oil filters. Does the hydraulic reservoir system have a filter?
3. The manual says have the dealer change the brake fluid. Is this necessary? Any tips on how to change it if it should be changed.
This unit is a 2019 and has 420 hours.
Thank you.
Thank you.
