I have a Kubota B3200, perfect for my use. I use it occasionally for lifting, transporting and mild grading.
Suddenly it wouldn't start, acted like a low battery. "click, click, click" starter solenoid.
I connected jumper cables to my pickup, still "click, click, click". Cable to starter read 12.5 volts.
Wire from key switch to starter solenoid reads about 3 ~ 4 volts when turning key to start.
Jumper wire from battery cable at the starter to the tab the switch wire connects to and the starter works fine
and engine starts right up. So, either the switch is bad or a rat ate the wire.
I know what to do, I don't know how to go about it.
How do I remove the plastic schroud (cover) that the switch is mounted to and the steering wheel shaft goes
through? Looks like it also contains the instrument cluster.
Yes, I know I could run an external wire and switch (button), but I like the conveniece of the std. switch.
My parts manual doesn't show me any of that area.
