I recently acquired an L3600, which doesn't look to have been well-maintained, though it starts fine and runs like a watch. However, winter is coming and I want to make sure that the coolant is more than just water (though it seldoms freezes hard in this the coastal UK). Problem is that I can't find the radiator drain plug which, according to p.65 of the manual, should be a kind of wingnut more or less in line with the radiator. In can't see anything like that, though I haven't removed all the panels yet...
If the worst comes to the worst, can I just remove the hose coming out of the bottom of the radiator on the right hand side (looking forward from the cab) and drain it that was?
Thank you!
Thank you!
