Thanks everyone. YNot, thanks for the photo of your sprocket. Judging from the looks of mine, its probably in need of replacement. What do you think? The bottom sprocket looks brand new.
How do I get this big sprocket off?
I've removed the two set screws, but it seems like the axle is flared at the end, and while i can get some movement, it stops dead when the sprocket is flush with the end of the axle.
It seems like any adjustment in the alignment of the sprockets is intended to come from moving the top sprocket. I appear to be about 1/4" short of what I need. Is my only option to move the lower sprocket, or is there some way I might be able to adjust the top axle out to get the additional reach that I need? Any advice?
Grateful for you all.
