Hey countryx, I have used this machine to plow snow quite a bit. I'd say the best thing is the enclosed cab which keeps you both warm and out of the wind and snow. Wipers work fine in this application to keep the snow clear. Warm-up times are long, and Kubota recommends long warm up times mostly for the transmission. I set the hand idle to about 1500 RPMs to help speed the warmup, which is a big improvement over idle. The tractor pushes and drags snow very well, plenty of weight and traction.Hello Troverman, So how did the L4060HSTC perform during your first and now second winter season? You said that you were planning on using it to plow not blow snow.
My deckover is the max legal limit of 102” wide, same as an 18 wheeler. Six in on each side would fit but with zero room to spare. I wouldn’t recommend that much spacer…lots of stress on the rear axle. 3” max per side would be my recommendationWould 6" spacers all around have fit on your deckover trailer instead of the 2"? (Assuming 8' deckover)
Wow I had no idea it would be so tight.My deckover is the max legal limit of 102” wide, same as an 18 wheeler. Six in on each side would fit but with zero room to spare. I wouldn’t recommend that much spacer…lots of stress on the rear axle. 3” max per side would be my recommendation
I don't have a tape measure at the moment, but here is a shot of my MX6000 with 2" spacers and the R4 rims set to their widest, just to give you an idea of the width. Adding 8 more inches of width on top of that would be crazy. Maybe the MX is slightly wider than the L60 series, not sure. What would be your purpose of making it so wide? I mow on extremely steep slopes and this is the best, most stable setup I've ever had.Wow I had no idea it would be so tight.
What does the outside edge of your rear wheels measure?
