How to increase hydraulic flow L3400D?
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
798
698
E.
Missed this reply somehow.
Thanks for the link.
I searched myself for the PTO driven motors, but not the standalone system.
Curious about function: does it tie into existing flow system or would you need separate controls like a 3rd function?
Once I finish the heavy work I need to do, and only maintenance requirements are needed, I'll probably sell the Bobcat and maintain with my L3400DM, which an attachment like you've linked to might be a long term solution.
mine does not tie in. A completely different system, pto powered with its own valving.
my live 26hp @ pto runs a 20pgm pump fine.
2,298
You may be able to rent a lot of the skid steer implements when you need them for occasional use.
Kubie L3400D
L3400DT 4WD, SSQA, Bobcat T190, Flail mower, Brushhog, Brushshark, Ratchet rake
Jun 29, 2022
59
11
FredNeck Acres, Tejas
Mine being 29hp @ probably means I'll have to do some more research.
Thanks for that input.
I'll create another thread when the time comes.
5,770
Hope you take care of your new machine better than the 'know-it-all' next door. His used/abused Bobcat STILL has NOT seen ONE pump of grease in over a year of use......he did have his kid PAINT it though....
THREE totally bald tires and 'hammertime' SSQA clamps.....
9,127
My bobcat is a beast wouldn't trade it for anything.
I repowered mine from the original 36HP V1702IDI to a 59HP 2203DI, what a huge improvement.
Due to the blackout I can't tell the exact model you have?
T300?
Is it a high flow model?
That make a big difference on what implements you can run.
Kubie L3400D
Jun 29, 2022
59
11
That is the plan, to take care of it.
Recent birthday gift cards are going towards a DeWalt 20v grease gun.
DW since I've got tons of their tools already.
Kubie L3400D
Jun 29, 2022
59
11
T300?
T190 and yes high flow, or so I was told, and it does have the high flow option on the control panel.
I've hooked up the BrushShark already and attacked a clump of youpon brush, which will be my main target, which consisted of a good half dozen stalks coming out of a 4" +/- base and it cut it like butter. Then, still using the BS, dug in and popped the root out w/o straining.
9,127
Excellent model!
Non emissions Kubota V2403M-DI-T engine in that model.
A lot of available aftermarket and OEM parts are available to repair replace parts!
Kubie L3400D
Jun 29, 2022
59
11
Excellent model!
Thank You and non-DEF was a primary search point, based on recommendations.
Is there a forum such as this
that covers the Bobcat SSs?
9,127
5,770
Be sure to drain a bit of oil from the drive sections BOTTOM plug after it's sat overnight !
A friend found out the hard way, his had WATER in it... Froze 'lost' left drive....until he dagged it into his shop,heated it up for 6 hrs and then drained the left side of browny-white watery oil....
he was NOT a 'happy camper' over that 'little problem'......
Kubie L3400D
Jun 29, 2022
59
11
Not sure how this relates to my original or subsequent post.
Kubie L3400D
Jun 29, 2022
59
11
well you bought a USED Bobcat, just thought you might like to know about some of 'fun' you might be in for.
Oh, OK. Thanks.
Being in far southeast Texas freezing conditions isn't something we have but only a couple of times a season.
This machine has less than 30 hours on the clock since last service.
I've not had time to look into things like you mentioned yet, but I will as soon as I can acquire a service manual.
I've downloaded an operator manual to familiarize myself with the how to's of operating it.
One step at a time.
