Bx1880
Berno
Bx1880
Nov 27, 2022
Oregon
Hi guys
I need some help, I have a bx1880
It has r4 tires on it and I blow one,sizes are 24x12-12 on rear and 16x7.50-8 on the front, any how I bought a set of turf tires for it as I’m mainly on grass that been said here is the issue I bought them used the guy had them for three week and they were of a 2360 the rear is 26x12-12 and the fronts are 16x8.5-8 I’m. Not sure these are a match I thought the fronts should be -10??
Thanks for any input
captcow
BX1870
Nov 27, 2022
Rim diameter not as important as tire diameter. Youll mess up your 4wd with 16inch diameter front tires, need 18s
Bugzilla46310
2022 BX2680 198? AC 916H
May 22, 2022
176
173
Demotte, IN
The 1880 has smaller tires than the 2380 and 2680. If you have the larger rims also, i would think replacing all 4 would be OK.
Berno
Bx1880
Nov 27, 2022
Oregon
Yes you are correct however I bought a used set of tuff tires believed to be a set
The rears are 26x12-12
The fronts are 16x8.60-8
I think the fronts are incorrect and should be 18x8.50-8??
Thanks
Bugzilla46310
May 22, 2022
176
173
Demotte, IN
Thanks
Go to the Kubota USA site and you can get all the specifications.
4,915
The rears should be 24x12-12, not 26x12-12. The older BX tractors use 8" rims, and the newer ones use 10" rims. The tire size is what matters, not the rim size as far as the center section goes. I suggest that you sell them to someone that can use them, and then ask the Kubota dealer what the price will be for the four tires and wheels purchased on the Whole Goods Program. I know that the local Kubota dealer sells them for just about the cost to build customer loyalty.
armylifer
Mar 26, 2013
2,061
787
Thurston County, WA
Hi guys
I have a set of used stock turf tires from my BX1860 mounted on the rims. The rears are 24x12-12 and the front ones are 16x7.5-8. One of the front tires is leaking but I have a brand new tire to replace that leaking one. I took these off from my tractor a few years ago and replaced them with the larger stock tires from a BX2360.
Since I have no intention of putting these back on my tractor I am willing to trade you what I have for what you have. I have attached a picture of what I have. I live in WA just about 20 miles east of Olympia, Washington.
