Do you reverse your rear blade for snow ... any issues?
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,993
2,363
Western MT
I've seen a few people say they reverse their rear blade for snow to keep from digging in to the driving surface. If you do or did, was there any issues?
I reversed mine just to look at it. I wondered if the bolts/nuts were damaged by this process. No, I haven't tried it yet. My road surfaces I will plow are primarily gravel.
johnjk
Apr 13, 2017
1,822
2,248
West Mansfield, OH
I don’t reverse it but I do pull it as far Roth as possible then put it at a 30 degree angle to roll the snow off. It I’m dealing with 4-8” I’ll do the first pass down the middle with it straight and then the next two angled. To clean up or push piles back, I use the FEL
johnjk
Apr 13, 2017
1,822
2,248
West Mansfield, OH
Oh and I am 1300’ of gravel to the road. I get more rock in my grass from the FEL than I do from the rear blade
Benhameen
2012 Kubota L3800 HST W/FEL and 1963 JD 2010 row crop utility
Jan 27, 2013
713
136
Southern IL.
On my gravel drive I have turned my blade around and I’ve not damaged it in any way. It does leave a layer of snow of on the gravel which I prefer. I used to drag gravel all over the place trying to get all the snow off. I did realize that if I pile up all the snow in one location, once it melts thats were my gravel will be. We don’t get a lot of snow here, so your experience may vary.
RDinNHandAZ
Kubota BX1870, FEL, BX5450 Snowblower, back blade, customized snow cab
Jun 26, 2022
103
133
Lakes Region NH and Sonoran Desert AZ
I keep mine reversed all winter. If I have 4-8” of snow on the gravel I angle it and let it move the snow to the road side. If there is more I use the bucket and then the rear blade to push it away to the side. My new tractor has a front snowblower and I have paved the drive so I put a split PVC pipe on the scraping edge of the rear blade and will try it when we get snow (my son actually as I am in AZ). No harm to the rear blase on my old tractors after using it backwards for 20+ years. Actually it would be nice to see a rear blade with a smooth rear surface intended for this purpose.
7,366
Only one season under my belt with a back blade, but I do reverse it. Ready to go for season 2 and parked where I can get to it.
I sometimes use the box blade for wet stuff too.
ayak
L3301 HST
Feb 16, 2018
789
1,303
WV
For my gravel driveway, I turn my blade around and also add a cut strip of horse stall mat that I make a sandwich with:
Reactions: 7 users
jajiu
Jun 5, 2016
456
Rowley, Massachusetts
The first and last storms of the season are the worst for gravel driveways. Until it freezes solid it will be a mess to plow. I use a plow on the front and the back blade as a clean-up at the same time. I only use it backwards when I back up pus P1060006.JPG P1060005.JPG 100_0598.JPG hing snow away from the wood shed in my back yard so I don't dig up the lawn.
My Barn
Kubota, Ford
Sep 14, 2022
135
37
I've used my facing forward at a angle...At time reversing it and we have +300' driveway and it is gravel. Now my blade has skid shoes on it. Depending on snow I make one or two pass.
At times pushing the pile off with the loader...This has worked for 25 plus years.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,447
1,744
Kalamazoo, MI
Nope. I shorten the top link all the way which reduces the positive rake of the cutting edge to near zero. Works great pulling or pushing, and a lot less work overall. I rarely use the FEL bucket in the winter.
Bill in Martinsville
ZD326
Nov 26, 2022
Horsepasture Virginia
simple rule for this PUSH SNOW - PULL DIRT
jimh406
Jan 29, 2021
2,993
2,363
Western MT
I don't think you are talking pushing a rear blade, but I guess that's ok if you are talking feet. I'm not personally going to drive backwards for 1/2 mile, and that's just my driveway. More like miles if I do the unmaintained part of the county road.
A front mounted snow plow would be ok, but I can't think of any use of it other than snow. The rear blade has other uses.
jnschnit
B2601, BH70 BH, LA435 FL, RCK60-32 MMM, BX2763 Blade, ZD1011
May 10, 2013
139
46
newark valley new york
I always used mine in reverse. It enables you to pile the snow higher, especially if there is a lot of the white stuff.
jajiu
Jun 5, 2016
456
My front plow blade I purchased from Quick Attach can be converted to a dozer blade by putting in bolts to keep it from tripping the trip edge.
jyoutz
Jan 14, 2019
3,626
2,719
Edgewood, New Mexico
Yes, I reverse my blade to plow my gravel roads. I generally plow over 3/4 mile of road and the reversed blade keeps the gravel in place. I also do this in other times of years to do do the final gravel grading after pulling the gravel from the road ditches and shoulders with the blade facing forward. The reversed blade does a nice job of spreading gravel across the road. I have never seen any damage to the blade from doing this.
ferguson
L3130
Jan 19, 2022
333
138
w.v.
It depends on the volume of snow & wet heavy or dry fluffy ? I puled the blade at a angle in snow any kind up to a foot or so. Large volume & heavy over a foot bush. Agen did this with a 20 hp Ferguson 2weel drive for maney years.
Danl1957
Bx2380, fel, rear blade, mower, winch, JD 318, HD road king, sportster, boats
Sep 12, 2022
19
Vermont
Hi all,
Good reading on this post, my first year with a bx2380 and rear blade for snow, my worry is damaging a paved driveway. My dealer recommends reversing the rear blade and pushing snow. I plan to lengthen the top link to reduce the blade angle when pushing, yet still concerned about driveway damage. Does anyone use the high density poly edge on the rear blade or are my worries unfounded? Sorry if this was covered elsewhere.
3,401
Hi all,
Reversing the blade and pushing snow? Does this mean you would be doing everything in reverse?
Sometimes I do push backwards, but most of the time I go forward with the blade mostly angled, but the first pass might be with the blade square.
Pushing in reverse all the time would get old pretty quick. My neck and body speaking now I think...LOL
