Fuel leak L355SS
David-in-OK
L355SS, brush hog, box blade
Aug 2, 2020
58
Oklahoma
I have a fuel leak coming out of the hose on the left at my rear cylinder. It runs up to the shroud covering the gas tank. Can I pull it off and cut it back and reattached without causing a problem?
1,543
Assuming you mean the rubber hose that is the injector bypass back to the tank, then yes you can cut it. It probably doesn’t have much slack in it and will be very tight on the metal fitting so may just split again.
The dealer can probably get you a new one or possibly cut it from a bulk roll.
David-in-OK
Aug 2, 2020
58
Oklahoma
Anyway to run that hose to the gas tank? It looks like it's covered up pretty tight.
7,408
You'll need to remove the tank if you can't get to the tank side of the hose if you need to replace it.
1,543
Not really sure on your tractor but on my L185 the tube runs through a hole in the fire wall and the tank has a 90 degree barb right there that you can see and get the hose onto. I didn’t have to take anything apart but may have used needle nose pliers to get it on.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
656
268
Herald Calif.
You can get access to the top of the fuel tank to replace the fuel return hose. Remove the panel in front of the tank that the fuse block is bolted to. Good luck .
1,543
One mounted vertically on the horizontal plane with yellow w/black stripe is water temperature sending unit.
The horizontally mounted sensor with black w/yellow stripe is oil pressure sending unit.
Please verify that if you have a wiring diagram by using the wiring color to the gauge
David-in-OK
Aug 2, 2020
58
Oklahoma
I do. Wish I had a parts manual.
1,543
You can look at Kubota USA dot com for illustrated parts list and you can probably get a printed version from Messicks but the part numbers are old and could be superseded or unavailable. The on line version is the most up to date but the pictures are not that clear
David-in-OK
Aug 2, 2020
58
Oklahoma
Thanks for the help.
