I have the lower arms within a fraction of an inch of equal length, but the blade on the adjustable arm side is till close to 4 inches too high. There does not appear to be an adjustment on the blade for correcting this. Any thoughts?
I assume the tractor is level, and/or or sitting with the blade on a flat surface?I have the lower arms within a fraction of an inch of equal length, but the blade on the adjustable arm side is till close to 4 inches too high. There does not appear to be an adjustment on the blade for correcting this. Any thoughts?
I said that because the op said that in his original post. I should have said “If there is no adjustment”. Glad you have tilt.curious.....
There is no adjustment on the blade,
why did you say that ?
The OP never mentions which blade he has...
BTW...My blade DOES have 'tilt'....
