Hello all. Winter has arrived and I am having trouble with my snowblower. It's a 7 ft Farmking, 540 PTO, with a gearbox. When I run the unit empty there is no vibration in the PTO shaft and in the impeller. There is a slight wobble in the auger (7 ft wide) maybe and 1/8 in up and down at 540 speed. Everything seems tight but I continue to break shear bolts, it has 2 in the PTO input shaft which are 5/16 inch grade five, and 1 on the impeller shaft, a 1/4 inch grade five. These are the bolts recommended in the manual. It will break bolts, usually all three and it doesn't matter if it is a light load or pushed to the max. I'm really stumped, anyone got any ideas? I've run it at 540 RPM and slower but it makes no difference they still break.
