Home Made BX2380 Front Weight Bracket
BManFX4
BX2380, RCK60B, LandPride RTA1250, CountyLine RC5, Titan BX42S Chipper
Apr 14, 2020
32
Loudon, TN
Hi everyone. I am a new member here and I am enjoying reading various posts so far.
I use my 2380 mostly for mowing my property (2 acres or so of grass, 1 acre of woods). The side and rear is pretty steep so I started looking into adding weights to the front. The Kubota weight bracket the dealer had made me lose the brush guard. Since I prepare deer plots with this BX the brush guard is a must. Searching on the Internet did not produce any results that met my requirements so I broke out the MIG machine and made my own bracket.
I used factory holes in the frame to mount it so I didn't have to drill it and the brush guard opens without interference as well. I am going to add "ears" to it so I can put a rod through the weights and secure them with a padlock for those few times when it is on a trailer and I stop for fuel, food, etc.
I searched for Kubota weights and was not very successful in finding them locally. I ended up ordering John Deere units and I painted them orange. :) They are 42 lbs. each and the bracket weighs around 10 lbs. It really helps with stability climbing the hills.
BobbyK
1995 B2400
May 20, 2018
102
44
Petrolia, Ontario
Way to figure it out!
Welcome, post pic's of the weight bar if you have them.
If you did post a pic...it's not showing up.
BManFX4
Apr 14, 2020
32
Loudon, TN
Thanks !!
That's weird - I inserted 4 pictures in the post body and they show up for me??
EDIT - I uploaded them again and attached them to the post.
BobbyK
1995 B2400
May 20, 2018
102
44
Petrolia, Ontario
Looks good!
200lb plus hanging off the front I think should help:D
Who cares if the weights are J/D.
I got two 85lb International Harvester suitcase wt's hanging off the rear of my J/D 317...ballast for the front mounted snowblower.
4,090
Thats pretty cool,,, the wheel weights on my BX came off a Cub
3,499
Shoulda left ‘em Green. (Fewer people would want to steal them) :ROFLMAO:
JimDeL
Aug 31, 2022
363
404
Austintown, Ohio
I see you have a 2" hitch adapter on the front. Where did you source that - or did you fabricate it yourself?
SGT13
Bx23s, CB05 bucket, GS05 scraper, Shop made ballast, hangers, & anchor pts
Sep 2, 2021
14
12
Arizona
Outstanding. Very simply. Since I needed an anchor point at the front I fabricated a receiver combo so that I could add a weight rack. Didn't care much for the cost of weights so I used some reclaimed brake disks and made up some brackets to hook em on. The disks also hook on the 3 point ballast.
BManFX4
Apr 14, 2020
32
Loudon, TN
I made it myself. I used the factory holes for mounting - I don't want to drill the frame.
3,698
Nice Job!
I like that you did not have to drill new holes for it. I always try to avoid that as well.
3,698
Very elegant solution Devil Dog!
Nice welding and fab work for sure.
5,175
EXCELLENT !!!!
