Wire gauge
johnjk
Apr 13, 2017
1,462
1,272
West Mansfield, OH
Would someone be kind enough to measure their top link hook so I can use it to fabricate a new one for my B3200? Looking for the gauge of wire used. I imagine any B or L series would be a similar size. This is for the hook that holds the 3-point top link up when not in use. Thanks
Bugzilla46310
2022 BX2680 198? AC 916H
May 22, 2022
170
168
Demotte, IN
Asked to get a simple measurement on a JD425 in a JD site so I could locate an attachment point on an adapter I am making to use the JD 54” blade I have on my BX. Three months later, still waiting for a response.
3,316
JD folks are used to that…. it’s the same response they get from their dealers and the JD proprietary software.
dlsmith
BX2230, LA211
Nov 15, 2018
1,235
789
Goshen, IN
I'm going to do the same thing. I want to adapt the 54" blade off my JD430 to my BX. I have all the mounts that go on the 430, and once a couple of other projects are finished up, I'm going to get'er done.
What measurement(s) do you need? I think the 425 and 430 use the same attachment, and my 430 is in the shop with the snow blower on it.
Bugzilla46310
May 22, 2022
170
168
Demotte, IN
Just needed a height reference like how high is the center of the top hole that the blade mounting bracket pin snaps into. I guesstimated based on various photos I could find that had a decent angle. My brackets are drilled. Just need to make one more cut, dress the brackets, paint, buy the top hydraulic 4in1 bracket and new hoses, and flush the old hydraulic fluid. I’ll post pictures in the modification thread when I’m done, hopefully before the first snow!
