Installing Block Heater for M5660 SUHD
greenpasturesharvest
M5660 Tractor
Nov 3, 2022
Tennessee
I want to install a block heater on my 2021 M5660 tractor. I cannot find the plug that needs to be removed from the engine block so that I can install the heater plug. I have watched several videos (other Kubota models) and checked engine diagrams (on Messicks), but I cannot find an Allen head plug to remove from the engine block on this 2021 M5660SUHD tractor. The engine has sealing plugs (part number 15221-03380 ) but these are the wrong size and are not removable or threaded. Can anyone point me to the place on the engine block where I would install a block heater? Thanks.
5,188
Can you find a suitable coolant hose heater location instead?
3,399
That is probably what I will end up doing if I cannot find the block heater plug.
If you do find a plug, be very careful if it is the push fit rather than a threaded plug. There was a nightmare story here of a guy that tried drilling a hole into his plug in order to remove it, and ended up drilling right through the cylinder wall, which was a very expensive and unfortunate experience for him.
just a heads up…
5,164
There is no reason to drill into a press-fit freeze plug. Just tap it on the edge with a blunt instrument and a hammer (make that a registered and licensed hammer and user) and the plug will swivel enough that you can then grab it with a pair of pliers and pull it out.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,447
1,743
Kalamazoo, MI
Here are pictures of my factory engine block heater on my M5660. 20221104_174320.jpg 20221104_174337.jpg 20221104_174351.jpg Mine looks like a pressed in bushing, press fit O.D. and pipe threaded I.D. and the block heater screws into it. Mine is installed forward of the starter.
M5660 Tractor
Nov 3, 2022
Tennessee
I'll post a picture of my factory engine block heater on my 2020 M5660 when I get home for your edification. Mine looks like a pressed in bushing, press fit O.D. and pipe threaded I.D. and the block heater screws into it. Mine is installed forward of the starter.
Thanks, I would appreciate the picture.
M5660 Tractor
Nov 3, 2022
Tennessee
Here are pictures of my factory engine block heater on my M5660. View attachment 89919 View attachment 89920 View attachment 89921 Mine looks like a pressed in bushing, press fit O.D. and pipe threaded I.D. and the block heater screws into it. Mine is installed forward of the starter.
Thank you so much. That helps a lot. I was looking for an Allen wrench type plug like I saw on a YouTube video, but I see now that the block heater goes in place of one of the freeze plugs. I did not know what a freeze plug (aka core plug) was when I started this journey :)
Duke73
Kubota M5660SUHD
Dec 30, 2022
KY
Green pastures harvest,
Did you get the plug heater installed without any problems? I have a 2017 M5660 and am getting ready to install the 70000-00297 Engine Block Heater too. After last weeks winter storm, I’m not getting caught again without one!
Can you confirm that the part number above is what you installed? I had a really hard time researching the correct part number to buy for my tractor. I just got it in the mail today. I plan on installing this weekend but I am a bit intimidated with knocking out a freeze plug…no going back at that point. I just installed a threaded block heater on my JD tractor and it was simple. This one seems a bit more complicated. Appreciate any other tips in advance.
M5660 Tractor
Nov 3, 2022
Tennessee
I did not install the plug heater yet. I still plan to do it, and even started, but then chickened out. Knocking out the freeze plug is a little intimidating to me. I ordered the part on Amazon (Kubota 70000-00297 Replacement Frost Plug Heater for Tractor) , and just for a backup plan I ordered an extra freeze plug from Messicks (15221-03380-620). The Kubota dealer assured me that was the right part number for the block heater. Plenty of YouTube videos on the subject. I also plan on draining the coolant beforehand to limit the mess. I am due for a coolant flush anyway. My solution in the meantime is just to keep an eye on the weather and get everything done/preloaded before any cold-spells like last week. I live in a temperate area, so that works for me. We got down to -1 F during the cold spell but are at 60 F today. I did not have to run the tractor until the temps were back in the forties. Let me know how it works out for you.
