Think about it. The weight of a 6 foot shredder is significant, but it's how far back the weight is hanging on the 3ph that causes the issue. It's 6 foot back, and acts like a long lever. Get it to bouncing and something's going to give, it has to. The lower links and their mounting points are pretty stout. The upper part is too, but it's not as strong as the lower.
It is interesting to look at maximum 3-point lift specs and then at maximum 3-point implement weights. Kubota is trying to account for dynamic loading no doubt, but as I show below, the manuals are questionable to say the least.
I see lots of tractors running big, long plows on the back and see the tractors oscillating front to rear (bouncing) when the plow is out of the ground, without damage to the rear of the tractor. If the front of the tractor isn't allowed to move since it's chained down to a trailer, and the rotary cutter is basically suspended in mid air, this is probably the worst case scenario in terms of the load on the castings at the rear of the tractor as the cutter bounces up and down.
I've poured over the manuals for both the MX and the M and it's a $hit show how these manuals are put together. There's no rhyme or reason to some of the specs. For example:
M6060
Max lift capacity at lower end link > 4,189lb
Max rotary cutter width > 84"
Max rotary cutter weight > 1,200lb
Max flail mower weight > 1,760lb
Box blade max width > 72"
Box blade max weight > 1,000lb
MX6000
Max lift capacity at lower end link > 2,870lb
Max rotary cutter weight > 1,000lb
Max flail mower weight > 1,100lb
So an MX6000 is rated for a rotary cutter that's 83.3% the weight of an M rotary cutter but is rated for a flail mower that's 62.5% of the weight of the rating for the M? The manuals are full of these types of discrepancies. Oh, and according to the owner's manuals, the M and MX have the same rating for box blade widths and weights!! Yeah, right.
