Long story short. Had my l3901 serviced at local kubota dealer & 10 hours later it needs a new motor. Only has 394 hrs. Run it 3 hours with no trouble. Brought it back to my property bush hogged for 25 minutes or so and it would just die. Did it 4-5 times, let it run a hour with no problems. Let my mechanic( friend look
At it) fuel gauge didn’t work correctly and he assumed it ran out of fuel. Filled back up and would never start again. Took it to dealer and they said the injection pump and injectors was bad from water in the fuel. They performed compression test and said one cylinder had no compression and the other was half. 15k for a new motor. What should I do? Part out - have someone else look at it?
