Hello friends, I have a B6200 that last year was working fine. I don't use it very much and plan on selling. But now won't lift the 3 point hitch arms. I havee changed the filter and checked the hydro fluid level. Thanks, in adance for any help.
Pretty simple machine. There is a diverter valve on the right side just under the pump. If it is in the wrong position your lift won't work. Consult the owners manual for a description of the "hydraulic outlet block".Hello friends, I have a B6200 that last year was working fine. I don't use it very much and plan on selling. But now won't lift the 3 point hitch arms. I havee changed the filter and checked the hydro fluid level. Thanks, in adance for any help.
Thanks. There was a lift circuit for a blower. I disconnected it a good while ago and the arms lifted just fine until recently. I'll let you know after I check it out.Pretty simple machine. There is a diverter valve on the right side just under the pump. If it is in the wrong position your lift won't work. Consult the owners manual for a description of the "hydraulic outlet block".
Any hydraulic options or loader on the machine?
Thanks. I'll let you know after I check it out.I had a similar issue, there's a dial underneath the seat for the 3 point hitch pressure. I inadvertently turned it all the way down one day. Check and make sure a kid hasn't been turning knobs.
On that machine it is going to be real easy to check for flow and pressure.Thanks. There was a lift circuit for a blower. I disconnected it a good while ago and the arms lifted just fine until recently. I'll let you know after I check it out.
