12v or 6v
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
441
42
Atascadero
I have never seen a Kubota diesel that is 6 volt. I would bet that it is 12 volt. If you still question this look around on all the electricals and see what their ID tag says.
jboar
grey b6000 with tiller
Aug 7, 2012
Cupar,Saskatchewan
Everything is in japanese, even the battery doesn't have anything on it. I was thinking it would be 12v but wanted to make sure in case I ever need to boost or charge the battery.
kubotasam
Apr 26, 2010
1,211
134
Alfred Maine
As Motorhead says I also think it is 12 volt. Can you tell how many cells the battery has? (how many places to add water) Even a sealed maintenance free battery you can usually count the cells. If it has 3 cells it is a 6 volt battery. If it has 6 cells it is a 12 volt.
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
Another check,If the battery is staring the tractor ok ,if you hook a volt meter between the +ve and -ve poles it should read the voltage.
dave
