I’ve got new neighbors (corporate trying to develop a health “resort”) out of land after they didn’t do their homework. (They are the third owners of land which is land-locked behind my crossing pair of aircraft runways. Each prior owner conveniently fails to mention and apparently investors these days aren’t clever enough to think about access until they buy the land they think is a “gold mine”…. then they discover their access problem of having to cross FAA recognized aircraft runways.)
Anyway, I thought I’d help them by reminding them daily why their contractors don’t like crossing runways without guard-shacks manned 24-hrs with a crossing-guard.…. by adding some official “Stop-signs” at each crossing.
Yesterday I hitched-up the PHD with my 6” auger to use 4x4 treated posts …and was surprised to stick the auger about 15” down and break 3 shear-bolts. The claimed 4,000 lb lift-capacity of the 3-pt couldn’t extract it and using a crow-bar thru the u-joint to back the auger wouldn’t budge it.
I ended up driving the tractor back-and-forth a foot several times before it finally ”snapped” loose and lifted it out of the hole. The carbide “tooth” was snapped off on one side and bent on the other.
So I came back to the shed and used the shop press to straighten the bend out and welded both teeth into position rather than rely on another set of failed carriage bolts to hold them on.
(I had moved about 10’ over to try a different spot after the first set of shear-bolts…and after several attempts the result in the new spot was the snapped teeth and stuck again.)
Trying to think of how to beat the rock that must be beneath the surface.
