Last year I posted about a project where I rigged something up to get a rear valve hooked up on my backhoe's hydro lines. This works fine but it obviously means that the backhoe can't be used while the valve is hooked up.
So I'm not thinking about making a permanent installation. I believe my tractor (b2601) has 2 ports somewhere that are dedicated to hookup an aux valve.
1- Can someone tell me where those ports are? If you have a diagram that would be nice.
2- Am I gonna leak oil everywhere when I remove the caps on those ports?
3- In this type of installation, a PB wouldn't be required right? I would assume that the plumbing was internally built for this purpose.
Thank you.
Thank you.
